Old 08-05-2008, 11:20 PM   #1
Simoneau's Avatar
2005 25' International CCD
Jamaica Plain , Massachusetts
Trouble debugging my water pump
My factory-issued SHURflo pump started leaking last winter after an accidental freeze. I'm having trouble figuring out how to fix it. I see where the water is coming out, but when I open it up there's nothing obviously broken (see attached photos). Any ideas? Thanks everybody!
This is my model: http://www.shurflo.com/pdf/rv/product_data_sheets/pds-2088-422-144.pdf
ID:	65140   Click image for larger version
Simoneau is offline   Reply With Quote
Old 08-06-2008, 12:57 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
The water in the pump that froze quite possibly tore the diaphrams (3 lobes attached to the motor). There are re-build kits available for these, but I might suggest a swap-out for the newer Shur-Flo Extreme Sensor 4.0 variable speed pump. These are currently the best on the market, and the Airstream factory seems to think highly of them also........as the now use them in the new trailers.
Old 08-06-2008, 12:10 PM   #3
Simoneau's Avatar
Thanks for taking a look, Lew. Since the water was just coming out of the piece attached on the left, it thought it might be as easy as replacing that or maybe the diaphragm between it and the rest of the unit. No such luck, eh?
Water heater trouble beaubayou Water Heaters, Filters & Pumps 11 01-16-2017 06:28 AM
Water Pressure trouble grogan Plumbing - Systems & Fixtures 7 04-30-2015 05:47 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
Trouble shooting Furnace/Heat Pump/Air C? Kistler Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-07-2007 12:13 AM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
