Old 01-27-2014, 03:06 PM   #1
1978 25' Tradewind
winterhaven , California
Too many valves? Water Heater
By the pump and hot water heater, there are 4 valves, where the copper plumbing turns into grey pvc,I assume that they have to be aligned depending on if you are using city water or water from the holding tank. There is nothing in the owners manual or even a picture. How do I find out which valves should be open and when?
rogowolf is offline   Reply With Quote
Old 01-27-2014, 05:52 PM   #2
SteveH's Avatar
Common Sense , Texas
I'm not familiar with that particular trailer, and frankly not sure what you are asking, but there are normally three valves by the water heater, and they are used for bypassing the heater so you can winterize the trailer without filling the six gallon heater with antifreeze.
Regards,
Steve
Old 01-27-2014, 08:57 PM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Wish this pic wasn't so fuzzy. It is a diagram of a common 3-valve configuration used to bypass the water heater so as not to unnecessarily fill it up with 6 gallons of antifreeze. One valve blocks the inlet, another the outlet and the 3rd permits the bypass. The handles are typically oblong and turn only 90. In line with the pipe is open, crossways is closed.
Name:   ImageUploadedByAirstream Forums1390881214.104020.jpg
If one forgets to close the bypass after opening the other 2 come spring, the wife will complain about the water not being very hot. Don't ask, I just know. 😊
If this doesn't help, can you post a pic of your valves?
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 01-28-2014, 11:34 AM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Nice image, Silver Goose. May I ask then . . . if I blow all my lines out with compressed air, plus completely empty the hot water tank, I'm supposing that I don't need to break my knuckles setting those valve during winterization???
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 01-28-2014, 11:42 AM   #5
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Blowing out the lines is hard to do with the water heater in the loop.
If one drains it he must put the plug back in to blow out the lines and the water will refill the tank. So, the plug has to come back out again.
I bypass the tank with installed valves ( as above) and remove the plug to drain the water heater and then blow out the rest of the lines
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Water Heater Drain wlanford Water Heaters, Filters & Pumps 14 01-25-2012 08:12 PM
'73 Original water heater - keep or chuck? Jamiep Water Heaters, Filters & Pumps 2 12-16-2011 01:48 PM
Elect/Propane Water Heater Combo dkottum Plumbing - Systems & Fixtures 4 12-11-2011 05:41 PM
Water Heater gas valve repair Orland Dewey LP Gas, Piping, Tanks & Regulators 3 10-15-2011 05:33 PM
Electrical? Water heater? Water pump? robwok 1960 - 1964 Overlander 6 02-09-2011 11:53 AM
