Old 02-08-2016, 06:15 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
To Anode rod or not
Have 2015 FC 28 with Attwood water heater. Local mobile RV mechanic recommended using an anode rod, even though Attwood and Airstream suggested it was not needed. Any problems using anode rod?
DeltaRon is offline   Reply With Quote
Old 02-08-2016, 06:20 PM   #2
Images: 59
I would use a magnesium anode rod. An aluminum rod would be somewhat useless.
Old 02-08-2016, 07:16 PM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Well, I think I'd be more inclined to go with Aistream/Atwood!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 02-08-2016, 07:21 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Your RV mechanic knows not of what he speaks. Attwood water heaters are aluminum-lined and do not need anode rods. Some RV water heaters do, but Attwoods are not among them.
But if you choose to ignore both Airstream and Attwood's recommendations and pay for an anode rod that you do not need, then you would need a magnesium anode rod in order to protect the aluminum tank lining.
But you should be aware that the EPA's Primary Safe Drinking Water Standards call for a maximum level of 0 parts per million of magnesium in drinking water, meaning that if you use a magnesium anode rod in your water heater, you should never use that water for drinking, cooking, dishwashing, or bathing— any sanitary purpose.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-08-2016, 08:27 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
No anode rods are required or suggested for Atwood (that's one 'T') water heaters. In fact, use of an anode rod in any Atwood heater will void your warranty!
The 'other' RV water heater made by Suburban REQUIRES a magnesium anode, as it has a different tank composition.
Your 'tech' needs a bit of RV re-education.
Old 02-08-2016, 08:39 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Two word answer, "not needed". I came from blue water sailing boats where I had to change 4 anodes and 2 hull plates at least once a year. Nice to not have to mess with them in my Airstream.
MICHAEL
Old 02-09-2016, 12:06 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Hello Ron
I used to live in Cumming, and I know from experience that well water in that area is extremely corrosive. I lived in a little residential development called "Dogwood Lane" that had a shared well. At the time I was there the houses were around 20 years old and had been built with copper supply plumbing, and it all had pinhole leaks leading to expensive repairs. The pH of the water was between 4.0 and 5.0.
It is true that Atwood doesn't recommend using an anode, because the tank is aluminum lined. There is a chance that your local RV guy knows from local experience what works best for the water there, but I'm skeptical.
I would recommend leaving the water heater without an anode. If you fill up with water at home, I would suggest you talk to a water treatment company and get the pH tested and install equipment to neutralize it if necessary. Your home plumbing and Airstream plumbing will both last longer.
Old 02-09-2016, 12:12 PM   #8
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I agree, no anode. Insofar as the impact of corrosive water is concerned, remember that one "feature" of RV travel is that you will be getting your water supply from many different sources so the odds that they are all chemically similar is pretty small. Obviously this would not apply if you are stationary or always camp or fill your tanks at the same place.
Bob Martel
WBCCI# 5766
Old 02-09-2016, 01:03 PM   #9
Can'tt help it. My "TT" key stticks!
WBCCI #1105
TAC LA-4
Old 02-09-2016, 04:25 PM   #10
lewster's Avatar
Sorry for your troubles. Have you seen a specialist about it???
Old 02-09-2016, 05:31 PM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There are pills you can take for that...
Question about anode rod in WH ventport Water Heaters, Filters & Pumps 5 08-12-2012 06:01 AM
Bowen water heater anode rod pickerdd Water Heaters, Filters & Pumps 3 02-07-2012 10:54 AM
Anode Rod SilverCabin Water Heaters, Filters & Pumps 9 02-17-2009 10:23 AM
Atwood Bowen anode rod? Moonshot Water Heaters, Filters & Pumps 3 11-11-2003 07:37 AM
Checking the Anode Rod... ALANSD Water Heaters, Filters & Pumps 1 05-08-2002 08:23 AM
