Old 08-27-2006, 07:43 PM   #15
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
Ganglin,
The same thing happened to me, my unit had a by-pass on it, and I took it off, 2 days later...wet floor. I have not replaced it yet but took some advise and called down to camping world in BG KY and they have scratch and dents on the floor. The day I called they had seven 10 gal gas only for $106.00. All carry the new warranty. Typically it is the outside door that is messed up but you will want to use your old one anyway. Check them out.
Dave
drag'nwagon is offline   Reply With Quote
Old 05-19-2013, 04:44 PM   #16
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Originally Posted by lewster View Post
The first thing I did when I got my 19CCD was to add the RV-500. It is well worth the $$$ as you never have to change a tank, anode or anything else. It provides endless hot water if you're connected to shore water and I do love those long, hot showers!!!! Plus, you only burn propane when it is producing hot water......no tank to keep hot!
I know this is a very old thread, but would you still recommend this hot water heater? What about for a 1978 31' Sovereign?
GAStreamin is offline   Reply With Quote
Old 05-19-2013, 06:25 PM   #17
lewster's Avatar
Naples, FL , Hood River, OR
Yep! Still feel the same about the RV-500!
Old 05-19-2013, 06:32 PM   #18
GAStreamin's Avatar
Moultrie , Georgia
Thanks! Good to know!
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
hot water tank George Water Heaters, Filters & Pumps 1 06-26-2003 12:43 PM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
Sanatizing the Water Tank? 68 Suburban Fresh Water Systems 3 10-13-2002 12:22 PM
Water Tank???????? TheBigRedTruck Fresh Water Systems 3 06-14-2002 10:11 AM
