Old 06-15-2011, 02:56 PM   #15
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by Spot
... I thought that is what I paid the big bucks for? But I still love the little aluminum can, and will be patient with it. ...
Try to remember that most of the components are "off the shelf" standard items every RV maker uses. Things like the color coded water lines and access to valves is something Airstream does better than some others. On the other hand, there are some challenges due to design. Considering all the compromises, I'd rather tow the little aluminum can any day.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 06-15-2011, 03:29 PM   #16
2017 25' Flying Cloud
Marana , Arizona
Well, after messing with the system for a better part of the day, I still don't have hot water. On my last cycle, I got more air out of the system - where was it hiding? But still nothing but tepid water. I just put in a call for the Airstream Tech people to give me a ring back.
Spot
Spot is offline   Reply With Quote
Old 06-15-2011, 03:36 PM   #17
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
RAT'S
You mentioned that the burner cycles, how long does it stay on?
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-15-2011, 03:41 PM   #18
Marana , Arizona
So far, it stays on as long as I leave it on. 15 to 20 minutes has been the longest I have let it stay fired.
Spot
Old 06-15-2011, 03:49 PM   #19
Spot
If you are getting a good steady flow from the hot faucets, I would leave the burner on longer.
Just for the hell of it....gonn'a fire up Cloudsplitter now. Call 'ya back when the waters HOT.
PFC
RLC
Old 06-15-2011, 04:17 PM   #20
2008 27' Classic FB
Burkburnett , Texas
Spot
If you've opened the pressure relief valve and only water comes out, the tank is full. If I start with a tank of cold water, I personally wouldn't give it much thought if it took 45 minutes or so before it cycled off the 1st time. Is your WH both gas and 110 v? If so turning on the elec along with the gas will speed up the recovery.
AIR 47751
Old 06-15-2011, 04:43 PM   #21
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
You have have received a lot of good advice. All I have ever had to do with any brand is to leave a a hot faucet running a couple minutes until the sputtering stops, then turn on the water heater. It will take 30 minutes or more for shower hot water.
The water heater on your trailer is equipped with an over-temp sensor. If the tank is over heating for any reason the burner will shut down.
Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-15-2011, 04:59 PM   #22
Spot
Here are the numbers...started stone cold
15min....84*
30min....115*
45min....138* burner shut down
My take....leave it on till the burner cycles off. And take a HOT shower!!
PFC
RLC
Old 06-15-2011, 06:47 PM   #23
Marana , Arizona
Thank you, all. One of the things confusing me is that last summer, as a new trailer, we could actuate the water heater and have what seemed like almost instantly hot water. As I am not seeing the same thing now, I have felt that something is wrong. I will let in run longer in the AM, and hope for better results.
Old 06-16-2011, 08:35 AM   #24
Marana , Arizona
Success!
MORE air purged this morning (egads, how much air can a little trailer water heater hold?). I let the burner go for longer this morning, and I now have hot water. I doesn't seem like it should be this hard....
Spot
Help-dewinterizing and no water off freshwater tank bonginator Water Heaters, Filters & Pumps 6 06-12-2011 08:37 PM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
