Old 10-12-2010, 03:45 PM   #1
Teflon tape and water heater connections
I was just getting ready to hook up the water lines to the hot water heater and realized I better check before making a mistake.
This is a brand new Atwood water heater and I am ready to screw the plastic fittings into the metal fittings on the water heater. The question is should I use teflon tape with the plastic fittings or just screw the fittings in and be done with it?
Thanks!
Old 10-12-2010, 03:58 PM   #2
Images: 59
Be a Hong Kong Cavalier, and go commando.
markdoane is online now   Reply With Quote
Old 10-12-2010, 04:41 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Use the tape or it will leak. Will leak with tape if you don't get it tight.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
water pump connections? batt Water Heaters, Filters & Pumps 6 10-02-2009 07:55 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Shore power & water connections - where? malconium General Repair Forum 13 05-06-2008 11:36 AM
Fresh Water Tank Connections tgregory13 Fresh Water Systems 0 01-24-2007 05:40 PM
Shining and teflon coating Scot 1959-69 Tradewind 1 08-10-2006 10:08 PM
