Originally Posted by markdoane
Is it possible (if money were no object) to put a small tank heater downstream from the tankless heater? I'm thinking this would overcome a frequent complaint about tankless systems, which is the time required to fire up and reach temperature. I think that would overcome the problem of water wastage when all you need is a quart of hot water to wash a few dishes.
Don
It is possible with the right amount of money, but...
Water wasting waiting for it to get hot is a function of distance from the heating appliance to the faucet, volume of the water pipe, temperature of the captured water in that pipe, and the rise time of the heating device.
The way I see it you must over come these obstacles.
The best way to do this is shorten the run from the heater and speed up the temperature rise time.
This can be done by placing a tank type water heater right at the faucet but you just gave away the advantage of a tankless heater.
Give and take.
You might look at a small electric tankless heater (Point of Delivery), I have seen them in plumbing stores and could be adapted to take care of your problem.
The only problem I see is you could only use it when hooked up to shore power.
Give and take.
I am not aware of any small gas powered under sink units.
Good luck with your quest.
