Old 08-17-2016, 07:42 AM   #1
Tankless water heater mount
My penetration is a little too big to mount my new tankless heater in its old spot. Anyone dealt with this and have solution? Trim piece? 1970 sovereign 30'
paulmichie is offline   Reply With Quote
Old 08-17-2016, 08:07 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Get some 2024T3 aluminum, 0.32 thick or maybe 0.040. Make a piece that will fill in the extra space around your new water heater and rivet the new aluminum in place. Olympic rivets, sealed with Vulkem or something similar at installation should work.
Aircraft Spruce and Specialty Co. is a good source for aluminum, or the light aircraft maintenance people at your local airport might have a source, or even some scrap they would sell you.
Clecos are wonderful for holding a new piece in proper alignment until it can be riveted, but for a one-time project, I have seen very small sheet metal screws with nuts used as substitutes. Slow, but they work.
Check for a local chapter of the Experimental Aircraft Association (eaa.org). Those guys are usually very familiar with sheet metal work and would be a good source of information.
Stud Mount TV Mount on Shower Wall??? BASE729 Audio, Video & TV 0 11-29-2014 05:31 PM
Flush Mount or Surface Mount Skycop Water Heaters, Filters & Pumps 10 01-13-2008 07:59 PM
Tankless water heater FC54 Water Heaters, Filters & Pumps 20 10-27-2004 04:18 PM
tankless hot water heater imeynstein Water Heaters, Filters & Pumps 19 04-17-2004 02:58 PM
Tankless water heater spinolio Water Heaters, Filters & Pumps 3 12-21-2002 10:53 PM
