Old 11-19-2007, 07:35 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Tankless Water Heater
Hi:
Has anybody in this forum replace their water heater with a tankless water heater. If you have where did you put it. I see there are a few RV porpane water heaters on the market. One cost almost nine hundred dollars and I saw another one for 118 dollars. Both burn propane. If you have made this change and took pictures I would like to see what it looks like. My wife does not want me hanging a tankless water heater on the outside of the trailer.
Brian
Lothlorian is offline   Reply With Quote
Old 11-19-2007, 11:13 PM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Tigerless
For a bump...
I know not exactly info needed.
I have one in the house.
Is very room saving.
Instant hot water the second you open facet.
Never runs out of hot water...I turn it on first thing cold mornings, eat breakfast, and step into a steamy shower.
Only negative would be a slight drop in pressure.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 11-19-2007, 11:15 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
A little searching of previous threads will turn up lots of info.
Michelle TAC MT-0
Sarah, Snowball
Old 11-19-2007, 11:52 PM   #4
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
yes, and note that precision temp is the only tankless made for rv use.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 11-20-2007, 03:27 AM   #5
Lothlorian's Avatar
Yes have been researching water heaters
I spent last night looking at different tankless water heaters. I also checked out the RV500 which is not in the budget. I wrote to a contact for this water heater Tankless Hot Water Heater - (eBay item 280173414358 end time Nov-20-07 16:11:27 PST)
and I am going to try to find a contact for this company eBay Motors: NEW RV TANKLESS INSTANT WATER HEATER NATURAL GAS (item 110193725648 end time Nov-21-07 19:45:00 PST)
I want to put the water heater in the same place the current one is located.
SIU Bound
Old 11-20-2007, 05:23 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
SIU Bound
mr. SIU,
I have seen this Marey unit and although it is ISO9001 certified IT IS NOT CERTIFIED FOR RV USE BY THE RVIA!!!
This is a domestic unit that the e-bay seller is saying that can be used in an RV.
IT CAN NOT!!!!!!!!!!!!!!!!!!
It requires a top vent which the RV-500 does not and it is certainly not water-proof as the components in the RV-500 are. Thus, it is certainly not built for outdoor use, like in an Airstream.
The RV-500, while perhaps not within your budget, is the only tankless LP water heater that IS certified for RV use and is specifically made to be a direct replacement for a Suburban tank-type water heater. The other two RV approved tankless water heaters are diesel fired and also control the hydronic heating, costing in the thousands!!
I sell and install the RV-500 along with standard water heaters, and I can tell you that it performs very well. I have one in my 19CCD and had one in my previous 40' MoHo since 2000.
LP appliances are nothing to mess around with, and I would strongly suggest that you only use a unit that is built to withstand the rigors of traveling down the road, which the Marsey IS NOT!!!!!
Hope this clears the air on this subject.
Old 11-20-2007, 06:41 AM   #7
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Opinion:
We have a tank-less in our home (7 GPM) and based on the way it performs I would imagine that there is a very important variable with travel trailers that needs to be considered.
The variable relates to how you will deliver water to the tank-less unit.
City hook-up or your on-board fresh water tank.
With constant pressure from a city hook-up the tank-less will work great because you will be more inclined to let the water run, especially with the shower.
Conservation is usually the norm when using your 12v pump and fresh water supply. This is not the delivery system that is most favorable for a tank-less system.
If you do most of your “camping” in campgrounds with water and elec. hook-ups a tank-less should be ok. The shower is where the tank-less will shine if you are not worried about the amount of water consumption. As long as you don’t exceed the GPM the unit can supply, you could spend the day in the shower.
Lavatory and sink use is not where the tank-less system pays off. For the average household the pay off comes from not keeping the typical 40 gal. standing water heater hot 24 hours a day.
On demand systems save energy and energy costs by being off when not needed.
Summary: Where and how you use your Airstream should be a factor in choosing a tank-less system for your hot water needs. You might feel better abount being a water conservationist by using a standard RV water heater.
Hope this helps,
em.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 11-20-2007, 09:51 AM   #8
Lothlorian's Avatar
A Big Thank you!
I think this is the best forum. Safety is number 1 and I appreciate your comments. Since I won't be camping anytime soon maybe I can put the RV500 on layaway somewhere.
Thanks again
SIU Bound
Old 11-20-2007, 10:12 AM   #9
Radman's Avatar
1972 27' Overlander
Monterey Bay , California
Images: 129
Tankless RV-500
SIU,
I put one in the 72. Had a ten gallon unit in before the switch. Slipped into the same street side opening as the old one. PO stated 10 gallon unit worked fine. Yes, I replaced a perfectly good water heater for the tankless unit. Just had to have unlimited, almost instant hot water since we usually get full hook-ups anyway. I haven't plumbed it yet, I have other issues to deal with in my rebuild.
I totally agree with Lewster don't mess with something that is questionable. Life is too short. Precision Temp is a well run co. w/ excellent tech support. I wish more companies were run like theirs's.
Good luck.
Radman is offline   Reply With Quote
Old 11-20-2007, 12:42 PM   #10
Full-timer
1971 27' Overlander
Pumpkintown , South Carolina
Brian:
It might be worth thinking about how you use hot water, and just how you'd expect to benefit from a tankless heater. I can only relate that my old 10-gallon tank job gives me all the hot water this lone full-timer needs, and it stays constantly on just pilot. Of course, I embraced the concept of "Navy" showers long ago.
PS: The term "Navy shower" in no way implies the company of a shipmate. If anything, that generally uses more water.
It's not the heat, it's the stupidity.
Foureagles is offline   Reply With Quote
Old 11-21-2007, 06:34 AM   #11
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Thumbs up I will be installing the RV-500 in the next few days
Hi:
Has anybody in this forum replace their water heater with a tankless water heater. Brian
According to FedEx my new RV-500 water heater will be delivered sometime today. I have already removed the old Bowen from my 1976 31' Sovereign and will be installing the RV-500 during the next few days.
Removing the Old Bowen went well and I have taken pictures of the process. I will also be taking pictures of installing the new RV-500 and will post these along with other details as soon as the job is done.
Don
adonh is offline   Reply With Quote
Old 12-20-2007, 04:30 PM   #12
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
Hey Mr. Lewster,
will the rv500 fit into the opening where the old heater is located?
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 12-20-2007, 04:48 PM   #13
lewster's Avatar
Reganzo,
That depends......on which model you will be removing. The Atwood models are slightly wider and shorter than the RV-500 and it requires you to trim about 2-1/2" from the top of the opening (which is what I did when I installed the RV-500 into my 19CCD. It will, however, fit directly into the opening of a Suburban water heater.
Let me know if you have any other questions or need any other info on the RV-500.
Old 12-20-2007, 07:08 PM   #14
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I have a Precision-temp in my 1965 Carevel. It was installed by the fellow who had the trailer ahead of me. I have had to contact Precision-Temp support three times. First time was to get a replacement metering valve as mine was cracked, probably from freezing. They sent one right out $60 or so. Another time the unit quit working and they couldn't get me out of it over the phone. I was in Jackson Center at the Airstream factory for a tour. In the morning we drove to the Precision-Temp factory in Cincinati? I think. Got there at 9 am. By 9:02 they had water hooked up and the guy who built my water heater was checking it out. Needed one new circuit board and three sensors. They charged me for the board.
For the most part, the unit works very well. On ocassion, it acts up, needing to have the 12v disconnected in order for it to "re-boot", then works properly. They told me that sometimes "stray signals" come through the 120v at an RV park, get through the converter to the 12v system and cause a problem. When that happens, I disconnect the 12v on the unit, unplug from the RV park, connect the 12v back up tpo the unit and it works just fine. I then plug the 120 back in and go about life. It's a computer thing.
In cold weather it comes on from time to time to keep from freezing. So, you never want to leave it without propane and 12v in cold weather.
Tankless water heater GreatPumpkin Off Topic Forum 10 08-25-2006 03:28 PM
Tankless water heater dmadam Water Heaters, Filters & Pumps 26 01-19-2005 09:59 AM
Tankless water heater FC54 Water Heaters, Filters & Pumps 20 10-27-2004 03:18 PM
tankless hot water heater imeynstein Water Heaters, Filters & Pumps 19 04-17-2004 01:58 PM
Tankless water heater spinolio Water Heaters, Filters & Pumps 3 12-21-2002 09:53 PM
