Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 11-07-2002, 05:35 PM   #1
spinolio
spinolio's Avatar
Profile:
Tankless water heater
Anyone tried a tankless unit, I know it's not original equipment but it seems they're much more efficient, and weigh less. Thinking of putting one on my newly purchased MH. here's the link to the manufacturer.
RV-500
spinolio is offline   Reply With Quote
Old 11-07-2002, 07:22 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
It sounds like a great idea. I do see a few discrepancies, though.
First the very high $ 829.00 initial purchase price. Very steep for a water heater.
Second the fact that it's main propane savings are based on the fact that you will not have to keep the tank hot, but you will end up using more propane because you can and will now take longer showers and therefore use much more hot water. And these units run the entire time you are showering, or otherwise using hot water. I guess it would be worth it for a very frequent RV user, or a full timer, but i would go conventional for what I need my Airstream for.
Uwe
Old 11-08-2002, 07:37 AM   #3
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I thought about the tankless unit myself. But after replacing my old one, (Bottom of tank rotted out) with a new 10 gal. Gas/Electric, I find both of us can take a pretty decent shower and not run out of hot water. For the amount of propane I would save, it would take me 2 lifetimes to recover the cost of the unit. I barely used one 30# camping this year.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 12-21-2002, 10:53 PM   #4
DIMMER
Vagabond
DIMMER's Avatar
Profile:  1973 31' Sovereign
Semi, Pro Rock Crawler , Motorsports Photographer
How many BTUs are you looking at for $829.00? For that price i could run a shower and the washing at the same time... You can get one for a sink for about $60.00.....
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
DIMMER is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 11:29 AM
Tankless water heater FC54 Water Heaters, Filters & Pumps 20 10-27-2004 04:18 PM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 06:37 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 08:26 AM
