Old 10-01-2012, 09:06 PM   #1
1966 26' Overlander
Blue Ridge , Texas
Tankless vs tank
I have just purchased my first AS and am trying to get everything done as quick and as cheap as possible. I really don't want to use gas anything since the only places I plan on taking it have full hookups. However there is always that chance. Would tankless be the way to go. And if so can I go with the ones from Lowes or does it have to be one that is specifically designed for a travel trailer. School this newbie please!!!!!!!
redraider731 is offline   Reply With Quote
Old 10-01-2012, 09:23 PM   #2
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Eletric Tankless
I looked at the eletric tankless hot water heaters at length, but I could not find any that draw less than 30 Amps. Many AS have a 30 Amp hookup, so you prettymuch could only be running your hot water heater, and nothing elese. No AC, power inverter ETC.
You could go with a small tank eletric hot water heater, but you will not be saving much money. You could hook this up, and only use the elec side, it's pretty much about a cheap as you can get. If you get one w/o the direct spark it is bit cheaper.
SUBURBAN WATER HEATER - SW6DE - 6GAL GAS/ELEC W/DIRECT SPARK...Regularly $548.00 On Sale for Only $307.95 From PPL
Also, do you have one in there now? If it does not work, and it is eletric/gas, changing the heating element is fairly simple.
Tankless is the way to go if you don't want to run out of hot water, if you have a trailer full of kids, or just really like that long hot shower. If your at a camp with full hook ups, then a really long shower is possible. If you are filling your grey tank, it will be a shorter shower..
Silverflames is offline   Reply With Quote
Old 10-01-2012, 09:24 PM   #3
1969 29' Ambassador
And.. Do you have any pics to share of your new AS?
Old 10-01-2012, 09:32 PM   #4
1966 26' Overlander
Blue Ridge , Texas
Not yet. I
Using the forums app from my iPhone and am not quite sure how to add pics yet. But as soon as I do they will be posted. I'm super excited about getting my AS up and running. All my friends are so jealous that I bought it.
Old 10-01-2012, 09:51 PM   #5
1969 29' Ambassador
When you reply there is a little + next to send. Hit that and then select from photos. It's real easy.
