07-05-2008, 08:16 AM
1988 34' Excella
Marianna
Switch for Atwood Gas/Electric Water Heater
I just replaced my old gas only water heater with the ATwood Gas/Electric, I have been looking for the gas/ electric switch that goes in the bathroom. I have searched several vendors and they have nothing listed.
07-05-2008, 09:18 AM
1972 25' Tradewind
North Vancouver
, British Columbia
The switch came with mine. I think you can order one from Camping World.
North Vancouver, BC
07-05-2008, 09:22 AM
1966 24' Tradewind
Placerville
Hello, and welcome. I had a similar challenge so I went to my local Ace Hardware (any hardware) and purchased a lighted rocker switch and a matching switch plate to the plates in our coach. The rocker switch was a tad to large for the opening in the switch plate so I filed the opening until the switch slipped in. I epoxied the switch to the plate, cut the appropiate hole in the bathroom cabinet wall and viola! Of course you will need to tap into the wiring on the water heater switch and route it to where ever you want your switch. I recommend a lit switch because in an instant you know if the hot water is on. Of course, any switch will work, toggle, a light switch etc. If you haven't already discovered the Atwood heats almost instantly and will remain hot until you use the water so I find no need to leave the switch on when the water isn't needed.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
07-19-2008, 09:09 PM
1967 17' Caravel
Thompsons Station
, Tennessee
FreshAir- was your home brew solution work for the DSI model? If so, I can't figure out how you did it with a simple illuminated rocker switch. Atwoods wiring diagrams (attached) show a separate light for status that is not related to on/ off operation. If you have the DSI model, can you tell me how you wired the 3 wires from your Atwood?
I am assuming that I am going to need a rocker switch and independent luminary if I want to build a switch myself?
07-20-2008, 06:10 AM
You might spend all day trying to find an illuminated switch with separate taps for the light. Look for one with four lugs in the back.
I bought a separate panel light and mounted it next to the switch, same as the diagram but not in a common body.
07-20-2008, 10:31 AM
1966 24' Tradewind
Placerville
1000 words...
My gray matter is fuzzy as to just how I moved the WH switch. It must have been simple as I am easily confused with electrical jargon. The Atwood switch is located on the back of the unit. How smart is that because in my case I would have to empty the bathroom wardrobe and pull up it's floor to activate the switch each time. Sooo I 'relocated' (extended) the switch (from Ace Hardware) to to wall outside the wardrobe. The switch on the unit must be left in the 'On' position. I can't say to which model Atwood I have but it is gas or electric (110). I hope these pictures help you.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
07-20-2008, 03:15 PM
1988 34' Excella
Marianna
I found an outlet for the switch(adventurerv.net) with shipping around $15.
the swithch is for all atwood gas/electric models. To tell if you have a gas/electric from the water heater you will have four wires
white-electric
orange-gas
green-ground
blue-warning light
If you have only gas you will only have three.
07-20-2008, 04:13 PM
1972 25' Tradewind
North Vancouver
, British Columbia
Just a heads up for you. I found that the switch for gas doesn't work unless the 110 switch is off. Once the pilot lights, I then turn the 110 on.
North Vancouver, BC
07-20-2008, 10:33 PM
1967 17' Caravel
Thompsons Station
, Tennessee
Neil.
Thanks FreshAir. I have an only gas model with DSI, I guess that is what is throwing me off. It is different than your gas/ 110v. The wiring diagram PDF I attached to an earlier post calls for a switch with a side status light. 4 total wire connections. I want to connect the water heater to this DC panel: DC 6 Position - PN 8677 - Blue Sea Systems It has a LED next to the rocker switch and I think I could disconnect it from the rocker and use it as the status light that the DSI model needs to indicate if the pilot was lit sucessfully. Any thoughts if this will work? I emailed BlueSea looking for a rear photo of this model but they don't have any.
