Old 02-23-2015, 01:24 PM   #1
2015 27' FB International
San Francisco , California
Supplies needed on-hand for current model water heater replacement?
I've got a new water heater being delivered tomorrow (Atwood 6 gallon XT model), and I plan to install it myself, replacing our current Atwood on-demand unit. Before I get into the removal and replacement, I'd like to purchase everything I'm likely to need. Other than tools and teflon tape, what should I pick up in order to be prepared?
Thanks!
ciparis is offline   Reply With Quote
Old 02-23-2015, 09:02 PM   #2
2007 22' International CCD
Tubing bending tools may be needed to get gas line to line up right. Patience always. Sealants for the flange.
KE4GNK/AE
Old 02-23-2015, 10:06 PM   #3
1974 Argosy 20
Kooskia , Idaho
I always like butyl tape for the seal between the water heater and the exterior metal.
Old 02-25-2015, 12:23 AM   #4
Good calls on the above, thank you. Turns out I need some pex tubing as well; there isn't enough to get where I need to go for the cold water hookup. The gas tubing also has to be re-bent pretty extensively, since the new one connects street-side while the old one connects on the inside; don't know yet if I'll do all that bending, or just cut it and replace with some flexible gas line.
Old 02-25-2015, 12:26 AM   #5
Flex will not do well in a vehicle. It breaks. There's a reason AS uses copper with flare fittings.
Search forums for more skinny on that. Not a good idea...
KE4GNK/AE
Old 02-25-2015, 07:49 AM   #6
1974 Argosy 20
Kooskia , Idaho
Flex pipe is not to be used in an RV. Stick with flare copper lines.
Old 02-25-2015, 08:26 AM   #7
1998 30' Excella 1000
Livingston , Texas
Buy a brass plug for the flare fitting on the gas supply line. If you run into a problem with the replacement, and do not finish in a day, you can still use the gas to cook and heat your rig.
Siegmann is offline   Reply With Quote
Airstream Current Model Differences GaryIllingwo Off Topic Forum 2 07-14-2009 01:57 PM
black water tank supplies 58 Overlander Rat Pack Waste Systems, Tanks & Totes 1 11-01-2006 05:26 PM
Got my polishing supplies! AirHeadRik Cleaning, Stripping & Polishing 13 04-28-2005 08:31 AM
3 musings (refrig, brake controller, emergency supplies) casarodante Our Community 2 04-02-2003 11:23 AM
Survival supplies On the Road FrankR On The Road... 7 04-19-2002 01:54 PM
