Old 10-19-2010, 09:07 PM   #1
1973 21' Globetrotter
Saratoga , California
Suburban Hot Water Heater
Just bought a new 10 gallon hwh and it is smaller than the original. Does anybody know if there is a an insert made to take up the extra space from the larger hot water heater opening. If not any suggestions?
youdaman is offline   Reply With Quote
Old 10-19-2010, 09:33 PM   #2
x
XXXX , XXXX
as far as I know there is no readily available insert. Can you return the suburban? An atwood 10 gallon will fit right in. I replaced mine in my 73 with an Atwood 10 gallon DSI gas and electric version. I needed no modifications to the shell to install it.
wasagachris is offline   Reply With Quote
Old 10-20-2010, 05:22 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I had an old Atwood in my Trade Wind and it had a 2 piece shroud around the opening that was quit large. Replaced it with Atwood DS 10 gallon. I had to fab a filler piece for the sides and top edges from aluminum to cover the hole. Got the aluminum from Aircraft Spruce to match trailer skin. I used Olympic rivets and spaced them to match the factory spacing. I don't really like the look of the new door on the water heater, but I had no choice as the old heater was bad.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Atwood vs. suburban water heater what's better? briheath Water Heaters, Filters & Pumps 10 07-27-2009 05:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Atwood to Suburban Water Heater Sundance Water Heaters, Filters & Pumps 11 07-11-2007 10:40 AM
New Water Heater- Suburban vs Atwood PizzaChop Water Heaters, Filters & Pumps 5 02-26-2004 04:48 AM
