Old 10-03-2016, 09:49 AM   #1
nickclifford's Avatar
1972 31' Sovereign
felton , California
strange thing, Precision Temp on-demand water heater
hi all, strangest thing i just noticed.. walked past my trailer and could hear a fan running, it was my hot water heater fan. Just running all by itself for no reason. Water pump switched off, no pressure in the system, no tap open (and no gas ..)
It was as though trying to ignite heater . clicking and fan running? I'd left the 12v switch on inside trailer but that's not the issue here, it just tried to fire up of its on accord ! It should only do this once it detects water flowing through and ignites automatically.
Any thoughts ?
cheers, nick
my Precision Temp is relatively new, about 2 yrs old ..
nickclifford is offline   Reply With Quote
Old 10-03-2016, 10:12 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
From the owners manual,
http://www.precisiontemp.com/wp-cont.../RV550_IOM.pdf
Possibility, "Safety pressure switch may be out of adjustment. Contact PrecisionTemp or your nearest authorized service representative."
MICHAEL
Old 10-04-2016, 08:40 AM   #3
1972 31' Sovereign
felton , California
they suggested might be the temperature drop safety mechanism that kicks in if drops to freezing, this will kick in to stop from freezing ... it ain't that cold where i live ! Santa Cruz can be chilling and drop to freezing in January but it's been mild here still ..
Precision Temp Tankless Installed philipsinewe Water Heaters, Filters & Pumps 14 09-08-2016 08:57 AM
New from precision temp lewster Water Heaters, Filters & Pumps 6 12-20-2012 10:40 AM
Precision Temp Installation question ddstech Water Heaters, Filters & Pumps 0 07-10-2012 10:05 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
electric problem precision CANADIAN BOB Member Introductions 2 06-14-2007 01:33 PM
