Old 02-05-2010, 06:05 AM   #1
1999 25' Safari
WINDSOR , ON
Strange hot water problem
this is very strange, we never use our water heater but since we are staying in one place for 2 months thought we would try it. water is hot but when we turn on the tap water will come out hot for a few seconds then get cold again this will happen wether i turn it to hot or cold, thought it might be the tap but happening on kitchen and bathroom faucets????
garryg is offline   Reply With Quote
Old 02-05-2010, 06:19 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Have you checked your w.h. bypass? Dave
easyride is offline   Reply With Quote
Old 02-05-2010, 07:51 AM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I agree with Dave. Check and make sure your water heater bypass valve is closed.
I had a similar problem in my Sovereign and found out my bypass valve was faulty and never fully closed in the closed position.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Problem with hot water pressure Namakemono Fresh Water Systems 0 09-11-2009 03:21 PM
Hot Water Heater Problem Solved Larry71 Water Heaters, Filters & Pumps 5 04-19-2009 12:29 AM
Strange smell in my fresh water! frscott Fresh Water Systems 8 01-19-2009 10:20 AM
Too short hitch to open rear door - suggestions? Canstreamer Hitches, Couplers & Balls 12 12-03-2008 07:58 PM
Strange Electrical Problem DaveJ Electrical - Systems, Generators, Batteries & Solar 5 11-11-2003 12:00 PM
