Old 05-28-2010, 06:02 PM   #1
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Strange Hot Water Behavior
I would like someone to explain this to me.
The water heater is on, and full of hot water. The coach is hooked to city water. Shower is going fine, temp is adjusted just right. Part way into the shower I turn the water off at the shower head. When the water is turned back on at the shower head, there is a rush of hot water for a couple of seconds, then the water returns to the adjusted temp. Why the hot water?
Any ideas out there?
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 05-28-2010, 07:41 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
One possibilty, and I need more information, is that when you use the shower head shut off you confuse the water mixing valve and there is greater pressure on the hot side (for whatever reason) and when you release the flow the hot side gets through first.
Is the control a single valve or do you have a hot knob and a cold knob? If it's a single than that could be it.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 05-28-2010, 07:49 PM   #3
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
We experience the same in both the 84 and 77 models. I always assumed it had something to do with the density of hot vs. cold and that physics were at play.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 05-28-2010, 09:37 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The only thing I can think of is that the water in the heater gets under more pressure due to being heated. I don't know if there is a one way valve at the inlet to the water heater, but perhaps that would account for the higher pressure, thus the short rush of hot water.
I just thought it very strange. It's OK as long as you know it's going to happen. Sure was a surprise the first time.
Oh, it has a hot knob and a cold knob.
Old 05-28-2010, 09:43 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Hey, that may be it. With both knobs on, if there is higher pressure on the hot side, when shut off at the shower head, it may bleed some hot water back into the cold side.
Fun question.
Strange hot water problem garryg Water Heaters, Filters & Pumps 2 02-05-2010 08:51 AM
Strange 12v Behavior in '67 GT tphillips Electrical - Systems, Generators, Batteries & Solar 2 10-08-2009 06:58 PM
Strange smell in my fresh water! frscott Fresh Water Systems 8 01-19-2009 11:20 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Explain this Dump Valve behavior..... Chuck Waste Systems, Tanks & Totes 2 08-28-2003 12:18 PM
