Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 01-13-2008, 08:37 AM   #1
the welshman
the welshman's Avatar
Profile:
still no hot water at the taps
hi
been having this problem for which seems like forever . got a 72 ambassador . boiler lights up and heats the water (tested it at the relief valve on top ) but when i pull the mixer tap to the hot side no pressure at all ,and no hot water .tried every combination of valves open and closed in the rear bumper section , also checked by the bathroom side cupboard and toilet water supply . has plenty of cold pressure and water just no hot . problem is i live in the uk and every time i visit to use it i have to try something else . had a look locally to see if there is a moblie guy who does airstreams but not succeeded . as i use it to stay in cant empty it to take somewhere as id not have anywhere to stay or store my stuff while its getting looked at .,can anybody steer me in the right direction to find the fault .also have limited tools as i cant bring all my kit over from the uk bringing a few tools each time i come . by the way forgot to mention i stay at newport dunes rv park ca when i visit . look foreward to your help many thanks steve
the welshman is offline   Reply With Quote
Old 01-13-2008, 08:42 AM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Originally Posted by the welshman
hi
Steve,
So, where is your trailer, UK or Newport? As I understand it, the trailer is in CA, you're in UK..
If you want, I can help you next time you're in town. I live close to Newport Beach.
I wonder if the trailer has a water heaer bypass that is in the bypass mode? Or a blockage somewhere.
Uwe
Old 01-13-2008, 10:01 AM   #3
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
I'm a little confused by your description.
Is the problem that the water flows, but it's cold?
Or is the problem that the (hot) water does not flow?
Depending on what's happening, the solution differs.
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 01-13-2008, 10:33 AM   #4
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
I think he's saying no water flow on the hot water side at all - at least that's how I read it. Think uwe is on the track. If you turned the bottom bypass to bypass but didn't open the top bypass valve - would that not shut down the flow all together. The opposite combination would do the same I think...
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 01-13-2008, 11:37 AM   #5
ve3czn
Profile:  1974 Argosy 20
Burlington , Ontario
Yup you have a hot water tank by-pass that is inb the by-pass mode. Look for some taps at the hot water tank and there will be some for sure.
Rae
ve3czn is offline   Reply With Quote
Old 01-13-2008, 12:48 PM   #6
Igor68
Wagon Master
Profile:
water tank
I had the same problem with a '68. I was going camping the next morning and was testing every thing first. I found the problem after a bit of testing. It ended up that there was a Calcum build-up( from hard water) in the HOT out pipe in the tank. Right where the Copper flair fitting attaches. I could get the tank to fire, fill, drain but not water presure. I just CAREFULLY drilled out the blockage (RELESE THE PRESHURE FIRST), flushed the tank, let it fill and spill out the open line to clean it. Put the line back on and it worked great. Hot water tanks are one of those things the allways gets over lookes at maintenence time.
Igor
Igor68 is offline   Reply With Quote
Old 01-13-2008, 12:52 PM   #7
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
i found one of my factory installed bypass valves installed backwards. (they have arrows on them indicating the correct flow direction)
the water flow would remove the washer from it's seat and block the flow.
fun figuring that one out!
john
you call them ferrets, i call them weasels.
Old 01-13-2008, 02:14 PM   #8
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Good advice so far....but there is another possibility that has not been mentioned.
If he has a check valve on the hot water outlet fitting at the tank, it may be calcified shut or simply defective. In either case, it should be replaced.....preferably with an all metal one.
I see this a lot when folks hit FL and can't get any hot water flow from their heater.......only problem is that the access to the check valve is usually almost impossible!!!!
After looking at the bypass, I would pull that check valve (if it is there)and replace it!!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 01-20-2008, 12:07 PM   #9
the welshman
Profile:
hot water help
hi thanks for all the replys. sorry my description was a little unclear not always easy to type the events so that they can be clearly read .yes the airstream is in ca im in the uk .i will be back at the dunes in october for my holiday ,so if uwe could send me a private message with his contact tel no id be very glad of all the help i could recieve . the hard part for me is living the other side of the world and trying to get alittle further with it every time i visit . streamer is in storage up in stanton at the minute ,cant wait to get back out thanks again for all the helpfull advice cheers steve . from a cold and WET uk
Kitchen faucet taps needed michael foster Fresh Water Systems 4 01-13-2008 05:37 PM
hot water water on demand with a with a normal water heater 62overlander Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Hot Water jfowler218 Water Heaters, Filters & Pumps 1 09-09-2006 09:10 PM
water leak- hot water tank vent glacierrunne Water Heaters, Filters & Pumps 2 05-29-2006 07:14 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
