Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 07-01-2008, 04:28 PM   #1
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Question Stays lit-water heater pilot light
Pilot light stays lit when I turn the blue knob to off position, thermostat set to minimum.
Only way I can get it to go out is to shut off the propane tank feed line.
Atwood, 1 year old GC6AA-8.
I discovered this while flushing the tank.
Now I'm wondering if I turn on the propane tank will raw propane be leaking out of the pilot light until I relight it?
I want to tow next week, always turn off the water heater but leave the fridge on.
Something broken?
www.popasmoke.com
Proud Appellation American
Vine View Heights, by appointment only
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 07-01-2008, 04:40 PM   #2
Pfredd's Avatar
Profile:  1978 Argosy Minuet 6.7 Metre
1977 31' Sovereign
1977 Argosy 24
Cincinnati , Ohio
If you can turn the gas back on and light the pilot light without turning the blue knob, then yes, you will leak propane.
There SHOULD be an individual shut off valve for each propane appliance. It is normally located on the gas line that runs underneath the trailer.
As for what is wrong, sounds like a bad gas controll. Have it looked at by a RV dealer, especially if it is still under warranty....
Visit my web site for Airstream Photos, Projects & Blog
Pfredd is offline   Reply With Quote
Old 07-01-2008, 05:52 PM   #3
INSANITY CENTRAL
doorgunner's Avatar
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Update;
When I turn the propane tank on I light the stove to get things going. Then I went back to the WH and put my flame on the pilot- nothing for 5 minutes. Then I move the blue knob from off to pilot, apply the flame and pilot lights.
Then I move the blue knob to off and the pilot stays lit, weird.
So I shut off the tank and the cycle goes on.
I'm NOT a fan of most RV repair places, I just need to understand how this thing works. You know something like theory of operation, If I can understand it then I can bypass it, Kinda like the law.
www.popasmoke.com
YETI ( 65 Quart )
Old 07-01-2008, 06:05 PM   #4
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
Another concern would be, what happens if the pilot light blows out. Will the gas stop flowing after the thermocouple cools off?
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 07-01-2008, 06:15 PM   #5
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Turn it to "off" and blow the pilot out. Wait five minutes and see if you can relight it without turning the knob to "pilot" . If that is the case you won't have a safety problem or a leak. What you want to establish is that the pilot safety system is functional.
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Atwood HW pilot light won't stay lit LI Pets Water Heaters, Filters & Pumps 9 12-30-2007 03:42 PM
Pilot light won't stay lit abridges01 Refrigerators 5 09-24-2006 11:01 PM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater pilot light help? PolisherGuy Water Heaters, Filters & Pumps 5 05-13-2006 08:41 AM
Pilot Light won't stay lit Mike Callaha Water Heaters, Filters & Pumps 15 03-26-2005 12:56 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
