Old 12-30-2007, 10:12 AM   #1
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Question Soot from water heater exhaust
My water heater exhaust has started pumping out a load of soot. It is all on the outside skin up to the blue band.
Before I take it in to be serviced, can anyone tell me what is causing it?
1. Has the thermocouple have anything to do with it?
2. I would guess it has something to do with air mixture....burning too rich. Is there a way to adjust?
3. I am assuming that it is not a dangerous situation, but correct me if I am wrong.
Bob (K5RPS) and Gail (MAAAA)
31' 1981 Excella II
2001 F-250 7.3D Crew w/8'bed and Pullrite 180degree
"Ask the Man Who Owns One" (Packard, Of Course)
or
"Ask the Woman who lives with one...or more!" (Gail)
ole81 is offline   Reply With Quote
Old 12-30-2007, 10:33 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Cobweb in intake tube?
Check out this suggestion from Jack Canavera. I watched him take it apart -- small fingers and small combination/open ended wrenches will help. The soot up the sides was severe until the spider web was removed.
5 meter Langford Nahanni
Old 12-30-2007, 10:34 AM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
It's not a good situation. Here's my sage advice (worth about as much as a wooden nickel):
1. It's not the thermocouple. Thermocouples are safety devices that shut down the gas (propane, in your case) when they're cold. If the thermocouple is bad, then the pilot will light while you've got the button depressed, but it won't continue as flame after the button is released. (We just replaced two of them, one for a wall heater in the cabin, and the other for the water heater for the bathhouse.)
2. It probably is air mixture. You should first check for some kind of blockage. (A dead moth can really muck up the works!) If there's no blockage, then there is usually some kind of small plate near the propane entry line that allows you to adjust the amount of air coming in. Adjust to a nice, blue flame that doesn't hiss too much.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 12-30-2007, 11:45 AM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Likely a spider web in the mixture tube.
Michelle TAC MT-0
Sarah, Snowball
Old 12-30-2007, 11:57 AM   #5
2004 25' Safari
1971 27' Overlander
Jourdanton , Texas
Given your location I would add mud daubbers to the list of culprits. The last time mine produced soot, a good blast of compressed air cleaned the debris.
pienjim is offline   Reply With Quote
Old 01-02-2008, 04:12 PM   #6
ole81's Avatar
1981 31' Excella II
Richmond , Texas
Many thanks for the input. I cleaned out the tube, did not actaully find any obstruction, but also moved the air throat and the soot problem has gone away.
31' 1981 Excella II
or
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Soot from Atwood water heater pilot light nickcrowhurst Water Heaters, Filters & Pumps 4 12-10-2007 12:29 PM
Water heater soot bkahler Airstream Motorhome Forums 4 02-24-2007 07:43 AM
Entrance Door Covers Heater Exhaust Jim Clark LP Gas, Piping, Tanks & Regulators 13 10-15-2006 05:39 AM
Hot Water Heater Exhaust Damage Road Ruler Water Heaters, Filters & Pumps 11 11-11-2002 02:27 PM
