Old 07-09-2013, 11:23 PM   #1
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
Solar Water Heater, Anyone?
Does anyone have any experience with solar water heaters of the type that use external heating plates? My '51 Flying Cloud does not currently have (among other things) a water heater. I'm thinking of mounting a solar water heater on the roof, but definitely not eager to drill holes. That said, I'm also not eager to cut an access port in the side for a propane water heater. What say you? Thanks!
calais66 is offline   Reply With Quote
Old 07-09-2013, 11:55 PM   #2
68Streamline's Avatar
Cerritos , California
Here is my 2 cents. I opted for an electric on demand water heater on my '58 Flying Cloud. For a couple of reasons. I replaced a 80 lbs propane heater with a less than 3 lbs heater to minimize the overall weight. Second, i will not be using hot water much u less i have full hookup. If im dry camping, i will minimize the use of water, and propane so no long hot showers.
68Streamline is offline   Reply With Quote
Old 07-10-2013, 01:09 AM   #3
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
We have a 66 caravel and although I thought about one for my house (not going to happen) but never for the Caravel because we are space challenged! I think that you would probably do better with a portable solar hot water heater of which I saw the plans for one, I dont remember if it was in the mother earth news or on some prepers sshow.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 07-10-2013, 12:08 PM   #4
calais66's Avatar
The heater I'm looking at has a panel of about 24"x24" so it would fit between the hatches on the roof. Just not sure how effective they are or how warm it would keep the water at night.
Old 07-10-2013, 12:14 PM   #5
timmaah's Avatar
1999 25' Safari
On , the road
Do you have a link to the part? I'd love to research it a bit.
I am really surprised there are not any solutions for RVs out there.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 07-10-2013, 12:21 PM   #6
calais66's Avatar
Here's the link:
http://www.heliatos.com/Solar_Water_Heaters.html
It seems like a good deal, but want to get feedback before I start poking holes.
Old 07-10-2013, 12:28 PM   #7
calais66's Avatar
And more specifically...
http://shop.heliatos.com/EZ-37-Solar...ls-0710007.htm
Old 07-10-2013, 12:49 PM   #8
timmaah's Avatar
1999 25' Safari
On , the road
Very cool. My wife would love one of those hooked to the roof. Seems a waste to turn on the propane for 5 quick minutes of dish washing.
You would still need a tank of some sort and a pump to cycle the water through it. That would get annoying if it is as loud as our normal water pump.
But yeah, the source and return line routing is a bummer.
Also odd that the spec sheet doesn't say anything about how many degrees you can expect to heat X amount of water in X amount of time.
Old 07-10-2013, 01:33 PM   #9
calais66's Avatar
Yeah, it seems that when it comes to pumping water there's no free lunch. But I'm leaning towards it from a cost as well as a 'not cut a hole in the side of my AS' perspective.
There's a video review online that shows it heating to 100*+ on a 70* day, so I think it would be efficient, at least in sunlight.
Old 03-06-2018, 07:51 PM   #10
1967 20' Globetrotter
Winchester , Virginia
Did you do it? I just installed 🙇 Heliatos panel on my 67 GT I'm rehabbing. Since the inner skins are off, I've run copper inside the walls.
ncrowe is offline   Reply With Quote
