Old 10-19-2014, 06:05 PM   #1
jasperkins's Avatar
2012 27' FB Eddie Bauer
colorado springs , Colorado
Smoking water heater in electric mode
We have a 2012 27' and the hot water heater has just started smoking....literally!! It smells like a burnt tire, smoke is coming from under the sink around the tank somewhere. Now in my testing, I turned off the electric and just turned on the gas to the hot water, no smoke. What broke on the electric side of the heater that it smells like burnt wires?
jasperkins is offline   Reply With Quote
Old 10-19-2014, 06:08 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
It is probably burnt wires.
Better turn it off and find the problem before the trailer catches fire. I watched a 1 year old OB burn from what the fire marshal said was probably a wiring failure this spring and it was not a pretty sight and the cat did not make it out.
Old 10-19-2014, 06:44 PM   #3
jasperkins's Avatar
Thanks for the reply. We are in the Adirondacks (NY) fulltiming. I might have to find a campingworld or airstream dealer for a quick repair!
Old 10-19-2014, 07:06 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I had a similar experience several months ago with the electric water heating function on my 2012 FC 23FB. I smelled burning wires and shut it off. It was a burned relay in the electric unit. I was able to replace it myself with a new one that I ordered on line. During the time that the electric water heater was off line, I was still able to use the gas water heating function. If you do this monitor the system closely as the thermostat may have been impacted.
Brian
SuEllyn & Brian McCabe
Old 10-19-2014, 08:23 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yeah.. might be a good idea to only run the gas when you need it...
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-22-2014, 09:17 AM   #6
jasperkins's Avatar
It was the relay!
Thanks for the quick responses. I had a local RV repair shop that was servicing the park look at the hot water heater, and indeed it was a relay. a few $$$, and 15 minutes and problem was solved. In my mind I paid the premium for the now and quick repair. However this truly is an easy fix.
Old 10-22-2014, 09:31 AM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Glad it worked out Jason!
Bob Martel
WBCCI# 5766
I quit Smoking RichardT Off Topic Forum 404 01-27-2015 09:54 PM
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
No Smoking at AIR Forums CanoeStream Fun & Games 31 04-02-2008 10:31 PM
Diesel Smoking JodynJeep Tow Vehicles 6 10-15-2003 02:24 PM
Honda 2000 smoking on start up Raptorrider2001 Our Community 3 04-05-2003 01:17 PM
