Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 07-04-2008, 09:06 AM   #1
iHayley
iHayley's Avatar
Profile:  2007 19' Bambi
Augusta , Georgia
slow drip behind outside water heater door
So I just noticed this, sitting here having my morning coffee, but when my water heater is fired up, I observed a slow drip of water, not hot, emerging from the bottom of the panel the covers the water heater. Is this normal?
iHayley is offline   Reply With Quote
Old 07-04-2008, 09:08 AM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
It's probably the plastic drain plug weeping. Our water heater (a new Atwood) does the same thing occasionally, maybe a couple of drips every 5 minutes or so, then nothing for a week or more. It all runs outside the trailer, if there is even enough for it to accumulate enough to run anywhere.
Old 07-04-2008, 09:31 AM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
The drain plug is a common place for a leak but it could also be the pressure relief valve. If you look inside the door you might see a drop of water at either of these locations. The drain is the plastic plug at the bottom and the relief valve should be toward the top on the right side. Be careful with both of these items. The water is under pressure in the tank and it is hot.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 07-04-2008, 09:36 AM   #4
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Look very closely at the drain plug and the safety valve once you open the door to the water heater. It is not uncommon for the safety (T & P) valve to weep. You can 'flick' the handle to emit a small burst of water (HOT!!!) to re-seat the gasket in the valve.
If these are NOT the culprits, you have remove your bed platform to check the 2 water fittings at the back of the water heater. These should be 'hand tight' but might have loosened from traveling and might be weeping. Usually, just a 1/4 turn will do the trick, but it is a real PIA to access the rear of the heater.
Have fun!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-04-2008, 11:21 AM   #5
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 35
Mine weeps constantly from the pressure relief valve when hot. It drips into the burner assembly which puts the flame out. The heater is constantly relighting during the heating process.
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
Old 07-04-2008, 01:10 PM   #6
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Air Gap?
Sometimes a weeping relief valve is caused by a lack of an air gap in the tank. See this from Atwood.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 07-04-2008, 01:45 PM   #7
Westfalia
Westfalia's Avatar
Images: 35
Thanks for the PDF. I'll play with it this weekend and see if I can make it stop.
Old 07-04-2008, 04:04 PM   #8
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
ganglin hit the nail on the head.
there needs to be an amount of air in the heater to absorb the change in volume as the water expands.
read your heater manuals regardless of make or model, it is explained fully.
john
you call them ferrets, i call them weasels.
Old 07-05-2008, 11:23 AM   #9
lewster
Commercial Vendor
lewster's Avatar
Why don't you guys just get an RV-500 and you'll never have a 'weepy' water heater again!!!!
AIR # 10325
Old 07-05-2008, 11:45 AM   #10
vajeep
vajeep's Avatar
Profile:  1976 27' Overlander
Richmond , Virginia
Images: 49
Brass plug
Just switched our plastic plug for brass. Our heater is under a year old and I could never get that plastic plug to stop weeping. It took alot of teflon tape, but no more weeping!!!
I also flushed my hot water tank, wow did alot of gunk come out...I would never have guessed that this much stuff could come out in less than a year. This will be a twice a year flush out from now on.
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
vajeep is offline   Reply With Quote
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
Vintage 70's Shower Door and Water Heater Door -- Freebie maccamper General Repair Forum 4 10-10-2008 08:35 AM
Old Door - New Water Heater Ganglin Water Heaters, Filters & Pumps 14 09-04-2007 11:33 PM
Wanted, water heater access door and frame, and "Service center" door. till Parts Archive 1 01-27-2004 12:43 PM
Fresh water tank - slow drip drboyd Fresh Water Systems 5 07-24-2003 08:01 PM
