Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 02-23-2003, 03:53 PM   #1
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Pilot light adjustment
Ok Gas gurus here is an easy one.................
I have installed a new water heater. I purchased a LP with pilot model that also has the factory AC element.
The thing I cannot figure out is how to adjust the pilot light. The pilot burns with a 1.5 inch flame and for the last week I only heard my water heater main burner light off 3 times. Yes we both took daily showers!
I just noticed this fact last night as I was re-lighting the heater after we moved to a Generator friendly location.
TIA
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 02-23-2003, 04:15 PM   #2
Profile:
The water heater being always on, should not have anything to do with the height of the flame. (ours has no adjustement.)
This looks more like a problem with the thermostat.
Mike
femuse is offline   Reply With Quote
Old 02-23-2003, 04:16 PM   #3
PeterH-79MH's Avatar
Profile:
Images: 63
Must be a trick question
you adjust the pilot light by turning the pilot light adjustment screw. It is located at the thermostat and usually has a cover screw that needs to be unscrewed.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 02-23-2003, 04:19 PM   #4
Profile:
Good think you remind me about that screw, I had forgotten about it. Mostly use the heater on electric.
Mike
Old 02-23-2003, 06:53 PM   #5
Just a member
Images: 21
I was looking for an adjustment screw, but it was dark and rainy, so I did not take the time to look under the big screw. I will do so and report back!
Brett G
Old 02-23-2003, 07:45 PM   #6
Just a member
Images: 21
Well, I pulled the big screw and there was an adjustment screw of sorts. I lit the pilot and set the knob to on and the main burner lit. I turn the screw to the right...... nothing changes. So I turn the screw to the left and ....... nothing changes. I noticed on the exterior of the thermostat there is wording that says pilot adjust but above that in a small circle it says no?? Meaning that I have no pilot adjustment?? The pilot works fine, I just wanted to cut down on the propane usage So I guess it goes on the gripe list for the RV place unless I can get more sage advaice from my fellow sufferers.
Brett G
Old 02-23-2003, 07:59 PM   #7
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
where's edie?
brett,
ever hear the saying "if it works, don't screw around with it"?
just kidding!
how is the better half?
john
john hd is online now   Reply With Quote
Old 02-24-2003, 03:32 AM   #8
Just a member
Images: 21
John,
I agree on the if it works don't mess with it, but I am striving to make everthing the best I can and the size of the pilot light just seems wasteful. I have been told that at times I am a___ renentive (you fill in the blank) so I tend to spend a bit more time and money on things. Sometimes it makes no real difference.
The better half is fine, she is recovering form a hetic week at the Florida State Rally, thanks for asking.
Brett G
Old 02-24-2003, 08:17 PM   #9
Profile:  LOST , Hawaii
Have you checked LP pressure, maybe it is high.
John
74Argosy24MH is offline   Reply With Quote
Old 02-25-2003, 04:04 AM   #10
Just a member
Images: 21
When I replaced the Regulator due to it leaking I checked the pressure. I have exactly 11 inches WCP. I am going to use it as is and have my local RV guy check it next time I take it in for something I can't do or don't have time to do.
Brett G
Pingbacks are On
Pilot light in Frig niftypkg Refrigerators 9 04-10-2005 12:04 PM
pilot light on water heater kthomson Water Heaters, Filters & Pumps 2 12-30-2003 08:38 PM
help me see the light wheel interested Our Community 1 11-17-2003 07:34 AM
Magic Chef Oven pilot sammamishsafari Stoves, Ovens & Microwaves 2 08-22-2003 08:17 PM
Ref pilot Dbraw Refrigerators 2 08-27-2002 04:43 PM
SEO by vBSEO 3.1.0
