Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 09-14-2002, 10:58 AM   #1
Profile:
Water Pump
I just located another leak in the water distribution system (the 3rd one!). Every time I fix one, I find that there is another. This time it seems to be a cracked bottom plate on the water pump. I've removed the pump and took off the plate. Anyone know if the plate is available as a replacement part?
Craig is offline   Reply With Quote
Old 09-14-2002, 02:19 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Craig,
It all depends on the type of pump. There are rebuild kits available for the Par pumps, I am unsure regarding the sureflo models. Unless you are trying to keep it all original you may be as well off to get a new pump as to try to find a repair part. It all comes down to a matter of time and money. It sounds like your trailer might not have been properly winterized You may be chasing leaks of a while. Good luck.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 09-14-2002, 05:15 PM   #3
Profile:
In case anyone has any info, the water pump assembly I have is the PAR 36800 (AS part #600267). And if anyone has an old water pump lying around, I'm just looking for the bottom plate.
Thanks!
Old 10-17-2002, 07:02 PM   #4
Retired and Retreaded
edmatlock's Avatar
Profile:  1972 26' Argosy 26
Oklahoma City , Oklahoma
I might have. Since I also have an argosy MH, I am concidering turning my argosy 28' 1972 into an office in the front.
But it might be better to just buy a replcement. Since I have two to worry about I keep a spare.
ED MATLOCK
edmatlock is offline   Reply With Quote
Old 10-17-2002, 07:52 PM   #5
Gordon Watt's Avatar
Profile:
Talking Par water pump
Craig:
I just happen to have what you are loking for. The pump is all apart and am willing to send the whole shootin' match to you, or you can pick it up next time you are in Winnipeg, Canada. lol
I took it apart thinking I had a pump problem and busted one of the bolts, so I bought a new pump.
Gordon Watt is offline   Reply With Quote
Old 10-18-2002, 06:23 AM   #6
Profile:
Gordon,
Thanks, but I found the part I was looking for through a Jabsco repair center.
But how much $ do you want for yours? I wouldn't mind having the spare parts.
Craig
Old 10-18-2002, 08:05 AM   #7
Profile:
Water Pump
Hi Craig:
The pump is free. You pay for transportation.
Old 10-18-2002, 09:26 AM   #8
Profile:
Gordon,
Thanks. Just sent you an email with my address. Let me know if you don't get it.
Craig
Pingbacks are On
Water Pump David Hall Water Heaters, Filters & Pumps 8 01-12-2004 08:31 PM
Water Pump will not turn on AccessMaster Water Heaters, Filters & Pumps 2 12-07-2003 02:08 PM
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 12:12 PM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
SEO by vBSEO 3.1.0
