View Poll Results: Which do your recommend, the Shurflo Whisper King or the Shurflo Premier water pump?
Shurflo Whisper King (2.0 GPM) 1 100.00%
Shurflo Premier (2.0 GPM) 0 0%
Voters: 1. You may not vote on this poll
Old 07-13-2004, 05:52 PM   #1
Shurflo Whisper King OR Premier? Choose!
Greets,
My '04 22' CCD has the Shurflo Premier 2.5 GPM water pump. Frankly, the pump is noisy - very noisy - when running.
I have a newly rebuilt Shurflo Whisper King (supposedly an upgrade from the Premier model) that I replaced on another A/S a year or so ago. The warranty was still good so I sent it in and now have an extra pump...
Was wondering before I dig in and start taking stuff apart if you all think it worth the effort or will I regret the .5 GPM difference between the two pumps. I'm certain I would appreciate the noise reduction.
What do you think?
67caravel is offline   Reply With Quote
Old 07-13-2004, 06:02 PM   #2
LOST , Hawaii
If you are talking about water use/conservation, it is only going to flow as much as you let it. You might not have to open the valve as much, but I don't think .5 gal/min. will be so great that you can't compensate. If it is significantly quieter I would swap, they are noisy.
John
74Argosy24MH is offline   Reply With Quote
Lift needed for king size bed! markparker22 General Interior Topics 29 03-01-2005 09:16 AM
Why did you choose a trailer? Hubba Our Community 25 04-18-2004 07:08 PM
Aquajet vs. Shurflo Silvertwinkie Water Heaters, Filters & Pumps 14 08-29-2003 07:49 AM
King of tail slap? Chas Airstream Motorhome Forums 11 07-31-2003 02:19 PM
Shurflo regulator_50 psi is not 40 femuse Water Heaters, Filters & Pumps 6 03-28-2003 10:54 AM
