Old 05-17-2006, 05:29 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Shurflo pump problems
Almost finished with my 65 Caravel airstream everthing is working fine execpt my pump, the old owner said that he put a new one in, and when I flipped the switch on, you could here it running. I filled the water tank for my first time turned on the pump it started and everything was great and all of a sudden it stopped, all the wires seem to be connected, I turned it off then back on and I could feel a slight vibration to the motor then it stop again,
any idea would help, this is my first time trying this
toastie is offline   Reply With Quote
Old 05-17-2006, 05:34 PM   #2
Retired.
. , At Large
Uhhh...
Did you have a faucet open when you tried it? The pumps are designed to shut off when they reach full pressure, and turn back on when the pressure drops.
Old 05-17-2006, 06:10 PM   #3
toastie's Avatar
1955 22' Safari
yes, they are open and than I turn on the pump and it will not turn on
Old 05-17-2006, 06:14 PM   #4
Retired.
. , At Large
Check the power and ground to it, ours had a ground wire that looked good, but didnt' make a good connection. When the motor ran without a load, it was fine, but when I put a load on it (water) and it drew more amperage, the ground opened and the motor stopped.
Old 05-17-2006, 06:19 PM   #5
toastie's Avatar
1955 22' Safari
I'm new to rv, if the pump is only 12v would it be possible that the battery is to low to run the pump
Old 05-17-2006, 06:23 PM   #6
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
check the in-line filter..If you don't have one, then you just might have a clogged impeller. Which means that, you'll have to take the pump apart to clean it.
BTW, if you don't have an in-line filter, after cleaning it..It's easy to put one on and, they're real cheap insurance. (Less than 10$)
Hope this helps you...
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-17-2006, 06:24 PM   #7
Retired.
. , At Large
Yes. You can try plugging into shore power, the Univolt will charge the battery, as well as provide (hopefully) enough power to run the pump.
Old 05-17-2006, 06:25 PM   #8
toastie's Avatar
1955 22' Safari
Yes, it has a in line filter
Old 05-17-2006, 06:28 PM   #9
toastie's Avatar
1955 22' Safari
The battery has been sitting all winter will I have been restoring, what is a shore power?
Old 05-17-2006, 06:38 PM   #10
Retired.
. , At Large
Okay, shore power is when you plug your trailer into 120V. Next step will be determining if you have a Univolt, or other form of 12v DC supply, but one thing at a time. If you plug it in, and the lights in the trailer get brighter, it is working.
Old 05-17-2006, 07:01 PM   #11
toastie's Avatar
1955 22' Safari
The trailer has been sitting since Nov will retoring, when I hook up the 120v every thing work great, all lights, heater, etc. then there is a box next to the wheel well with 2 toggles that I switch to city, when I unplug, and switch to battery ever thing goes dark, there is also another box on the other side of the wheel well that seems to be hmmmmmmmmmm all the time......
Old 05-17-2006, 07:09 PM   #12
Retired.
. , At Large
It Works!
The humming sound is coming from your Univolt (battery charger/12 volt DC converter). It is operating. Now, hopefully the pump will start working, too.
Old 05-17-2006, 07:21 PM   #13
toastie's Avatar
1955 22' Safari
Think you very much for you help, I'm going to have the battery checked out, get new hot and ground cables plus new fuse holder.......thanks again
Old 05-17-2006, 07:26 PM   #14
toastie's Avatar
1955 22' Safari
Old 05-17-2006, 08:32 PM   #15
Barkingdogg's Avatar
Newcastle , Oklahoma
Water Pump
Hi,
You may have found your problem already. One problem I had was with the pump. I replaced it because it would not work. I was using it on shore power. Now I have a replacement pump (in stock).
I guess the univolt was no suppling enough power to operate it properly. It would hum like it was working but did not. Worked when switched to battery. So now if I want to use the water pump, I use it on battery and keep the battery charged with a separate charger that I plug in when hooked to electric. Everything else works fine on shore power. This may work for you.
Barkingdogg
Barkingdogg is offline   Reply With Quote
Water Pump cycles often Guitars Water Heaters, Filters & Pumps 3 11-19-2002 07:04 PM
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 12:44 PM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 06:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
