Old 05-17-2006, 08:32 PM   #15
Barkingdogg's Avatar
Newcastle , Oklahoma
Water Pump
Hi,
You may have found your problem already. One problem I had was with the pump. I replaced it because it would not work. I was using it on shore power. Now I have a replacement pump (in stock).
I guess the univolt was no suppling enough power to operate it properly. It would hum like it was working but did not. Worked when switched to battery. So now if I want to use the water pump, I use it on battery and keep the battery charged with a separate charger that I plug in when hooked to electric. Everything else works fine on shore power. This may work for you.
Barkingdogg
Barkingdogg is offline   Reply With Quote
Water Pump cycles often Guitars Water Heaters, Filters & Pumps 3 11-19-2002 07:04 PM
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 12:44 PM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 06:31 AM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
