Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 10-31-2009, 12:21 PM   #1
Mike Leary's Avatar
Profile:  On the move , Las Cruces, NM
Shurflo Pump Problem.
I notice when the pump gets turned on, blackish colored water comes out for a short time and then clears. Any one have a clue? The pump is prolly 10+ years old. Thanks, M
1983 310 Turbo Diesel Mo/Ho "Bess" 212,835 miles
Full timing since 1994
Mike Leary is offline   Reply With Quote
Old 10-31-2009, 12:38 PM   #2
Commercial Vendor
Profile:  Corona , California
Mike.
Sounds like the impellar is shot.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-31-2009, 12:41 PM   #3
Mike Leary's Avatar
Originally Posted by Inland RV Center, In View Post
Mike.
Do I buy a fresh pump from you or are parts a option? Thanks Andy.
Old 10-31-2009, 12:52 PM   #4
Commercial Vendor
We only have the complete pumps.
I understand that repair kits are available, but have no idea from where.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-31-2009, 01:24 PM   #5
Mike Leary's Avatar
I'd figured on a fresh pump, I'll call in a order next week. Thanks again.
Old 10-31-2009, 02:12 PM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
He'd know if anyone would -- PM lewster. Give him the model # or some spec like that.
Old 10-31-2009, 02:17 PM   #7
Mike Leary's Avatar
Thank you sir.
Old 10-31-2009, 02:52 PM   #8
Mike Leary's Avatar
I just noticed with the pump off and on to potable, I still get the blackwater. Am I still pumping though the circuit and the wear is still happening? Odd that it quits in a few seconds.
Old 10-31-2009, 03:27 PM   #9
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Is it happening at every valve (hot and cold), sinks, shower and toilet. It might be a hose that is breaking down if you have a home made patch somewhere.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-31-2009, 03:37 PM   #10
Mike Leary's Avatar
No patch I know about; news at eleven. I'm thinking if I took on some skanky water somewhere,I'd have pumped it out by now. The fact that it's the same black on cold or hot makes me wonder.
Shurflo Water Pump Problem mello mike Water Heaters, Filters & Pumps 15 08-20-2009 01:32 PM
New Shurflo pump quit working? Lothlorian Water Heaters, Filters & Pumps 9 12-14-2008 07:08 AM
shurflo water pump, which one? urbanfood Fresh Water Systems 24 08-19-2007 05:37 PM
Shurflo water pump urbanextreme Water Heaters, Filters & Pumps 13 05-18-2006 11:18 AM
Shurflo pump problems toastie Water Heaters, Filters & Pumps 14 05-17-2006 09:32 PM
