Old 07-08-2016, 06:08 PM   #15
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
Went to the trailer yesterday, and found to trouble with little water flow. The filter was packed up. Removed it, and cleaned it. Great flow now.
What was a little more difficult was changing the cartridge in the Moen shower valve. The retainer clip would not come out, or the cartridge itself. In the heat of the trailer in a confined space ie. the shower and head I nearly had a heat stroke. I was completely soaked with sweat. Finally getting the whole valve assembly I headed for the wholesale plumbing supply we do some business with just up the road. They destroyed the clip getting it out, and 3 brutes pulling on it could not get it out. Finally we got a pulling tool. It worked with much coaxing. Part of the cartridge was broken off.
The problem was hardwater and probably well water with mineral deposits. That valve cartridge was really stuck.
Well. there was good news and bad news. They had the replacement cartridge but no retaining clip. So off to Lowes to see if I could find one there. Finally I found a bubble pack repair kit that had one. Of course I had to buy the whole kit. Then back to the trailerto reinstall the shower valve.
The water flowed, and cut off. No dripping. It doesn't take much to make me happy.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 07-10-2016, 12:16 PM   #16
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Originally Posted by OTRA15 View Post
How are you doing? Hopefully all fixed and on the road again!
Happy Trails,
Peter
Thank you everyone for the advice! I tried all the above recommendations, plus a few others, and unfortunately the pump seems to be completely kaput. It hasn't really been an issue so far because we've been staying at campgrounds with full-hookups, but whenever we stop along the side of the road for a pit stop it's been a minor annoyance.
A replacement pump is in order when we get back to home base.
Thanks everyone for the advice! It's great to have such strong community support.
trekerboy is offline   Reply With Quote
Old 07-10-2016, 12:34 PM   #17
Long Island , New York
Thanks for the update.
Happy Trails!
Peter
Old 08-11-2016, 05:44 PM   #18
trekerboy's Avatar
Turns out my pump was NOT defective after all. I had my more mechanically inclined brother come over to install the new pump I ordered and he determined that the old one was just fine, there was just a big air bubble in the line, presumably from when I emptied the tank. Cleared the air bubble and viola! It worked! For anyone else having a similar issue, check for air bubbles, especially if you recently ran your water tank dry.
Old 08-11-2016, 06:46 PM   #19
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Glad it wasn't something more serious. But I am curious how you cleared the "big air bubble"?
Hans627 is online now   Reply With Quote
Old 08-13-2016, 07:52 PM   #20
trekerboy's Avatar
I'm afraid it was something more serious: turns out I'm not as smart as I thought I was (something my wife has suspected for years). Haha
I cleared the air bubble by filling the tank all the way up, shutting off the shore water connection, then letting the pump cycle a couple times. I suppose alternatively I could have poured some water down the intake pipe leading to the pump from the tank...
So close and yet Sa-fari (adventures with our new 1971) dmroot 1969 - 1973 Safari 58 09-02-2007 02:17 PM
The adventures of Brett and Edie III thenewkid64 Airstream Motorhome Forums 54 02-14-2005 04:25 PM
Adventures of Brett and Edie Part II thenewkid64 Airstream Motorhome Forums 28 12-01-2003 01:36 PM
Adventures of Brett and Edie Part I ViewRVs Argosy Motorhomes 69 07-08-2003 07:06 PM
Any other's 26' other than 60's Overlander? 59toaster Our Community 4 03-21-2003 10:00 AM
