Old 09-15-2008, 06:13 PM   #1
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Shur-Flow Won't Quit
Hello all,
My water pump has developed the nasty habit of not turning off. It is a shur-flow, and has the same appearance as the new pumps I find pictures of here on the forums. The pressure switch seems to be mounted on the end of the pump, away from the motor. The pump works fine, with flow and pressure seem as normal, but the pump will not shut off after demand has ended. Any ideas?
Best Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-15-2008, 06:25 PM   #2
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Check that the filter mechanism just before the pump is tight and not allowing air to enter the line. We had that problem and it kept the pump running until I tightened the fitting.
SilverCottage is offline   Reply With Quote
Old 09-15-2008, 06:27 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The pump could be worn and is having a problem getting the pressure up to the cut off point. I replaced mine last year and it shuts off much quicker now.
Richard
I quit Smoking RichardT Off Topic Forum 404 01-27-2015 09:54 PM
'96 LY fridge quit working airstream96 Land Yacht/Legacy Motorhomes 5 07-02-2007 09:05 PM
Water Heater Quit again carnegie1935 Water Heaters, Filters & Pumps 5 03-20-2007 06:56 PM
**Chris Quit Blinking At Me** Silvertwinky Our Community 6 09-02-2003 11:11 AM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 03:02 PM
