Old 02-12-2019, 12:57 PM   #1
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Shuffling Pump
Is there an in-line switch or fuse link on the water pump?
I have no action on my Shurflo 4008 101 A65 in my 2017 FC.
think Iím missing something simple. Thereís water in the holding tank ... but no sputtering or cycling when I turn the pump on.
Cispook is offline   Reply With Quote
Old 02-12-2019, 02:11 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Assuming the pump is getting power....
There's a pressure switch mounted on the top of the pump. It's where the two wires with spade terminals connect, and it's held on to the pump body with three screws. If your pressure switch is stuck open, your pump won't kick on. An easy way to test this is to pull the two spade terminals off the pressure switch and then jumper the wires together with a piece of metal. If your pump kicks on, the pressure switch is stuck open. Disassembling it, operating the switch a couple of times, and putting it back together tends to fix the problem. Keep in mind that you'll be opening the water side of your pump, so you'll want to depressurize and drain your plumbing before taking those screws out.
TheGreatleys is offline   Reply With Quote
Old 02-12-2019, 02:58 PM   #3
Cispook's Avatar
Chillicothe , Ohio
Thanks. Iíll give that a try.
Old 02-12-2019, 04:18 PM   #4
Long Island , New York
In the 12-volt distribution panel, isn’t there a circuit breaker for the pump? Check your owner’s manual for the electrical schematics. This would be the next simple thing to try IMO.
Good luck,
Peter
Old 02-12-2019, 05:31 PM   #5
PS — also possible that the one or two wall switches controlling the pump have failed. Have you tried turning them on and off a few times to see if there is an intermittent problem? You could pull them out of the wall to see if a wire has come loose on the back of the switch.
Old 02-12-2019, 09:04 PM   #6
Cispook's Avatar
Chillicothe , Ohio
Originally Posted by OTRA15 View Post
PS ó also possible that the one or two wall switches controlling the pump have failed. Have you tried turning them on and off a few times to see if there is an intermittent problem? You could pull them out of the wall to see if a wire has come loose on the back of the switch.
Thanks - obvious fuses and connections have been checked.
Old 02-12-2019, 09:08 PM   #7
Cispook's Avatar
Chillicothe , Ohio
Noticed that the pump is listed also listed with model number ďe-65 RevolutionĒ. Anyone know if any difference between original model a-65 and the Revolution model?
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 02:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 03:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 11:11 AM
