Old 10-25-2018, 03:27 PM   #99
2017 Basecamp
2019 22' Sport
Roswell , Georgia
On my maiden voyage with brand new 2019 Sport 22- 3rd day in, no hot water; Southland RV came to my campground to replace the Atwood board; so depressing after spending 1 1/2 yrs with multiple issues with a 2017 Basecamp. Love my Sport but I need this to ALL work!
KayakGa is offline   Reply With Quote
Old 10-27-2018, 12:29 PM   #100
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
I noticed the Admin moved this post to a broader sub. That's good. I had been reading so many other threads that appeared in other subs and it is likely the Atwood problem on any AS can be solved by the Dinosaur board. So I post the location for everyone.
http://www.dinosaurelectronics.com/Ignitor_boards.htm
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign K5FT
Msherw is offline   Reply With Quote
Old 10-27-2018, 12:56 PM   #101
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I went through three OEM boards on my 2017 International. Finally put a Dinosaur in - works like a charm.
VaTravelers is offline   Reply With Quote
Old 11-13-2018, 05:59 AM   #102
This is why I love forums. Also why doesn’t airstream just buy the Dino boards and fix the problem? I, like others, just dropped a pile of cash for an AS why not fix these little niggling bits and call it a day? They could probably build order these for 50 bucks a piece.
Thanks for the heads up. Next up I’m gonna go through and check all screws and connections
I guess this will be my first mod.
I’ll add I’m no stranger to tinkering or modifying, my last dirt bike purchase became a mod fest of 2/3000 dollars worth of stuff, however that was all nice to have stuff not necessary to have, like in this case.
What else do I need to be looking for?
Kanusport is offline   Reply With Quote
Old 12-11-2018, 11:24 AM   #103
KH
KatHan's Avatar
2019 22' Sport
Santa Fe , New Mexico
Cool 3rd trip COLD SHOWERS 2019 Sport 22FB
Thanks for your water heater/striker board failure post. Our water heater failed on our 3rd trip in our new 2019 Sport 22FB. Cold showers in the Florida Keys in December were tough but not tolerable in below freezing temperatures on our return journey back to Santa Fe, New Mexico. Shame on Airstream for not doing proper quality control on the water heater components.
Worrisome that the replacement will only mean more cold showers in the middle of another 4 thousand mile plus round trip. Why canít Airstream do a recall and upgrade to Dinosaur striker board?
I wonít be recommending Airstream to anyone.
Burrr... in Mississippi,
Kat & Art
KatHan is offline   Reply With Quote
Old 01-13-2019, 09:31 AM   #104
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
Bad Atwood water heater circuit board
Our 2nd board just went after 30 hours of use on gas (We don't leave the water heater on all day) Now we are boondocking on the Arizona desert with our 8 month old trailer with cold water.
bolerama is offline   Reply With Quote
Old 01-13-2019, 10:18 AM   #105
2019 27' Globetrotter
Salem , Oregon
From reading this forum I guess I should go ahead and get a Dinosaur board on order. My trailer is supposed to come off assembly line tomorrow.
Do I need any mounting hardware or is a direct swap of the board.
Dave
NoResults is offline   Reply With Quote
Old 01-13-2019, 11:11 AM   #106
2017 27' International
Lake Havasu City , Arizona
Installing a Dinosaur board is about as easy as it can get.
For my 2017 International 27FB's 6-gallon Atwood water heater--and I gather for any Atwood that has 4-pin plus 6-pin cables on its igniter board--the replacement is Dinosaur's UIB-64. The board comes with a mounting adapter plate, a plastic cover, and mounting screws and nuts--everything you need.
I did this job last week. Installation took me only a few minutes, with nothing more than a small nut driver and a pocket knife (to pry the cables off the Atwood board). The Dinosaur mounting plate fits the Atwood screw holes perfectly. Plug in the wires and you're done.
Note: when doing the swap, use the shorter screws that Dinosaur supplies rather than the longer ones used by Atwood. Because of differences in the thicknesses of the two boards, the longer screws might press against the tank if used with the Dinosaur board.
Paprika is offline   Reply With Quote
Old 01-14-2019, 07:52 AM   #107
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Be sure you save the OEM striker board AND the Dino purchase receipt. Then call or email Airstream customer service and ask them for a refund on the Dino board since the OEM board was under warranty. Don't let anyone talk you into another OEM board swap. I went through 4 before the Dino. OEM boards are trash.
M!ke
Old 01-26-2019, 05:35 PM   #108
2018 22' Sport
No red light at Water Heater Switch
New-to-us 2018 Sport 22FB de-winterization and shake out trip complete in Galveston.
Only go/no-go issue: WATER HEATER INOP
Troubleshooting: Good propane (stove & furnace ops normal), good DC power (lights ops normal), good AC power (microwave ops normal), good water to trailer. H2O valves all correctly set. T/P valve bleed off checked. No luck bypassing thermal cutout. Red light at Water Heater switch never comes on when turned on. Water heater makes no attempt to light off. Suspect bad circuit board. Ordering Dino Board. Will report back.
FWIW, we never checked water heater at dealer because it was already winterized (Dec in Columbus, OH). Emailed Haydocy Airstream (purchased it there used) who said call Coach-Net. Coach-Net and Airstream Customer Service were polite but never mentioned the circuit board issue. They referred me to local AS dealer in Katy, TX which has a 2-month wait for service.
Appreciate everyone on airforum for sharing your expertise. I doubt this will be the last time I leverage your shared wisdom.
See you on the road soon!
GasStream is offline   Reply With Quote
Old 01-27-2019, 10:19 AM   #109
bolerama's Avatar
Images: 30
Update....
received a new board from Airstream. It's from a different manufacter (not from Zhandong). Airstream said there are having problems with the old boards. At first it didn't fire up. I thought I got another bad board. After about 10 seconds it fired up. So far I have been running gas only with no issues for 3 days. I will update this thread if it fails.
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
Old 02-20-2019, 04:13 PM   #110
2018 22' Sport
Update: Dinosaur board installed. H2O heater works! A couple highlights: 1) Had to set the pin jumpers correctly on the new board. Mine were initially set for a 10-pin vs 6-pin connection and had to be adjusted. Follow instructions that come with the board. 2) While checking connections at the H2O heater switch I discovered all wires were very loose. Secured and checked connectivity to the H2O heater with a multimeter.
Thanks again to all who share their knowledge via this forum. You may just turn me into a DIYer yet.
Old 02-27-2019, 10:12 PM   #111
waninae39's Avatar
2017 22' Sport
NCR , Ontario
after three board failures , we went with Dinosaur's UIB-64.
after 1 year no issues.
BTW, after many calls, emails and letter to atwood and airstream, i still cant my money back after sending them the last bad hw heater board.
Atwood sucks and lies and claims nothing was received
waninae39 is offline   Reply With Quote
Old 03-18-2019, 09:20 PM   #112
2018 22' Sport
Update: Airstream refunded us for full purchase price of the dinosaur board.
Door striker Rivets bwbuer Doors & Locks 3 03-12-2011 07:35 AM
Is this door striker available? vhord Doors & Locks 28 04-28-2008 06:38 PM
Pictures of '64 door striker? 59er Doors & Locks 2 12-03-2007 01:06 PM
Screen door striker Robfike Classic Motorhomes 5 06-03-2006 06:26 PM
Striker Rod for '66 Overlander draftwomyn21 Refrigerators 6 05-21-2006 08:20 PM
