Old 09-09-2014, 05:02 PM   #1
1977 Argosy Minuet 6.0 Metre
Rosalind , Alberta
Rubber heater plug??
Hi all:
I just purchased my new (to me) 1977 Argosy Minuet 6.0. Not many here in Alberta. So of my many questions, this one tops the list, as it's snowing in Alberta. The drain plug on the heater appears to be a rubber expansion plug that's seen better days. I have 2 problems: I don't know where to get a replacement, and if I attempt to remove it, it may very well disintegrate.
'Course another winter may remove it for me. Anyone else experienced this problem? Thanks
churchman is offline   Reply With Quote
Old 09-09-2014, 05:13 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
That is a standard plug for a 1/2 inch pipe. Go to any hardware store and you can get a brass one that will last longer than the plastic one.
Here is a link to the original plastic part on Amazon:
Amazon.com: Atwood (91857) 1/2" Drain Plug Kit, (Pack of 2): Automotive
Bob Martel
WBCCI# 5766
Old 09-09-2014, 05:14 PM   #3
Chelsea , Michigan
Images: 12
Oh, and my condolences about the early snow!
Bob Martel
WBCCI# 5766
Old 09-09-2014, 05:17 PM   #4
Rosalind , Alberta
So what you're saying is that inside there somewhere should be threads?
Old 09-09-2014, 05:20 PM   #5
Chelsea , Michigan
Images: 12
There should be. I am assuming that you have an Atwood water heater?
Can you post a picture of the plug as it appears in the heater unit?
Bob Martel
WBCCI# 5766
Old 09-09-2014, 05:22 PM   #6
Chelsea , Michigan
Images: 12
Does it look like either one of these:
Bob Martel
WBCCI# 5766
Old 09-09-2014, 06:40 PM   #7
Rosalind , Alberta
Looks like the bottom one. I'll try to get a picture
Old 09-09-2014, 06:56 PM   #8
Chelsea , Michigan
Images: 12
Pull the plug and then get a replacement at any hardware store. If there are threads, then get the 1/2 inch plug in the top picture (it will be more secure than the compression plug you currently have.)
Good luck!
Bob Martel
WBCCI# 5766
Old 09-09-2014, 07:04 PM   #9
Rosalind , Alberta
Still snowing tonight! I'll head to town tomorrow.
Old 09-09-2014, 07:51 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I removed the original plug and installed a boiler cock. Now it's just a matter of turning the handle to drain the water heater.
Old 02-20-2015, 11:21 AM   #11
Gainesville , Florida
Reviving an old thread. What to do after breaking off old plug? It was old and cold, just like me, and broke, just like me. Peace, jim
Old 02-20-2015, 12:47 PM   #12
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Jim, See if you can screw a large screw into it. Then try to work it out.
MICHAEL
Old 02-20-2015, 01:15 PM   #13
Okay, I'll try that. Jim
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
Bowen B10G water heater drain plug lebolewis Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-20-2008 11:49 AM
What's with the Rubber Plug in the Floor? bevman General Interior Topics 4 06-02-2007 02:53 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
