Old 05-12-2011, 06:19 PM   #15
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
-sniff-- I do so love happy endings...-snifff.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-23-2011, 07:02 AM   #16
asianmack's Avatar
2011 19' Flying Cloud
Chicago , Illinois
Thank you for this post! We were camping this weekend and noticed a ton of water coming out of our NEW hot water heater's pressure release valve. A ton, like the waterfall you describe.
Thanks to your post I'm getting a new pressure release valve now!
asianmack is offline   Reply With Quote
Old 05-23-2011, 07:13 AM   #17
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Just saw this thread- relief valves are notorious for leaking. At work we had to check them in houses by flipping the lever monthly. On a very regular basis they would not reseat properly and had to be replaced. So we had our maintenance crews carry spares. I always mean to throw a spare in the AS....
Old 05-23-2011, 08:06 AM   #18
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Glad we can be part of a solution. I will look for a place to buy a spare, and put it in my tool kit.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 05-23-2011, 08:52 AM   #19
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
And if it leaks you need to change it. It leaks down on the wiring and the ignitor and will cause corrosion and failure to ignite. I changed both the thermostat (went to and adjustable one) and the pressure relief and it was a very good change. I also had to clean the ignitor base and put in a new screw so that it was grounded.
Airstream water heater door LKSD Water Heaters, Filters & Pumps 9 03-23-2011 04:46 AM
Water Heater suggestions for '64 Overlander robwok 1960 - 1964 Overlander 4 03-02-2011 07:27 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
