Old 06-21-2004, 08:01 AM   #1
replacing water heater
Quick question we have a 24 Argosy with a Atwood water heater which appears to be leaking, my question is how do I remove the unit? the waste water tube from the sink and the inlet and outlet lines for the water heater appear fo be in the way to pull it from the inside so I believe it must come out from the outside. I am hoping someone could verify this for me.
thank you
1982 Limited 34
gmlcjb is offline   Reply With Quote
Old 06-21-2004, 08:53 AM   #2
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Smile Waterr Heater
thank you
I just replaced my water heater with the Atwood 6 gal. I have a 24' Argosy.
You disconect the water lines and then remove the rivets/screws on the outside and pull it out from the outside. The Atwood elec/gas/dsi is a great unit and not hard to adapt.
E-mail me at dpcarpet@sbcglobal.net or call me at 512-497-5120 if I can help you.
Don
Gunnyusmc is offline   Reply With Quote
Old 06-21-2004, 09:25 AM   #3
Thank you Don I will start and hope I do not have any problems, but I will certainly keep you informed.
Don
1982 Limited 34
Old 06-23-2004, 09:53 AM   #4
I was able to remove and replace the unit with no problems, thank you for your reply Don I wish you a most enjoyable summer.
1982 Limited 34
Old 06-24-2004, 05:53 AM   #5
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Thumbs up
Thats what the forum is all about!
Don
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
Water Heater Advice! John Sims Water Heaters, Filters & Pumps 1 06-16-2003 08:43 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
