Old 03-08-2010, 09:12 AM   #1
1973 31' Sovereign
Replacement Water Heater Mystery
Hi folks,
I live aboard my 31-footer and replaced the water heater with a 10 gallon (electric only) GE water heater about six months ago. Its been working great--the former owner had put in a similar one (but 2.5 gallons) and showers just weren't long enough.
Here's the funny thing. Two weeks ago I relocated my trailer and now I seem to be getting much less water out of the heater. It runs out in about 5 minutes instead of the 10 I got at my old location. The oddest thing is that if anything the water pressure is lower at my new location (so there aren't more gallons/minute flowing out of the shower head).
I'd love any theories/advice. Thought those navy showers (pits and bits) were a thing of the past.
seventythree is offline   Reply With Quote
Old 03-08-2010, 09:25 AM   #2
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Working theory: There is/was a big air bubble in the heater and it has allowed the upper element to burn out (which they happily do when not surrounded by water). Pull the upper element to see or check the continuity with an ohm meter.
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 03-08-2010, 09:30 AM   #3
1973 31' Sovereign
Good theory
One caveat: before plugging the electric on the trailer back in I ran the water on "hot" for several minutes to get the air bubbles out and get the system back under pressure. I only then plugged it back in.
Old 03-08-2010, 10:06 AM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I don`t know of any 10 gal.120v heater having 2 elements,even the ones with 2 elements,if the top burns out ,it doesn`t heat,the top element heats up first,then the thermostat switches to the bottom,and heats up the bottom of the tank.If the bottom burns out then you run out of water too soon. Dave
easyride is offline   Reply With Quote
Old 03-08-2010, 11:44 AM   #5
1973 31' Sovereign
Here is a link to the exact model. The owner's manual specifies that there is only one heating element:
GEĀ® Electric Water Heater | GE10P06SAG | GE Appliances
Thanks all. Also worth noting that its not a weather change. Incoming water temperature, etc should be WARMER than the last few months as this March in Texas.
Old 03-08-2010, 12:02 PM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Originally Posted by seventythree View Post
Hi folks,
Could be sediment build up reducing the amount of room in the tank. How to Flush a Water Heater | Video | Water Heaters | This Old House
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-08-2010, 12:38 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Quality of incoming power? Is the unit being fed through the conventional RV shore power extension cord - if so the outlet receptical at this location could be heating up from a high resistance connection - no warm spots anywhere in the wiring I hope...
The linked installation manual says thats 2000w of power and should have 10AWG wiring to the receptical - And if the new location is 1200 feet from the powco's transformer versus 120 feet at the old spot there will be a slight brown out effect from losses in the copper wiring. Are you fluent in Voltmeterese? You getting a solid 117VAC at the appliance when the line is under load?
Many many possibilities : )
Old 03-08-2010, 07:29 PM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I suspect you have air trapped in the tank.
To correct open the lever on the safety pop off valve to let the air escape.
Garry
Old 03-09-2010, 05:53 AM   #9
easyride's Avatar
1977 27' Overlander
Naples , Florida
I have to agree Wabbiteer,you are probably not getting enough amps there.Dave
live aboard, water heater, water pressure, replace
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water Heater Replacement? Evanelk Water Heaters, Filters & Pumps 1 06-24-2009 07:27 AM
Water Heater Replacement lebolewis Water Heaters, Filters & Pumps 2 05-13-2009 03:56 PM
Water heater replacement bmurr Water Heaters, Filters & Pumps 2 07-29-2006 10:24 PM
Water Heater Replacement (help) rdm General Motorhome Topics 1 07-14-2003 02:31 PM
