Old 07-18-2005, 02:43 PM   #1
1963 19' Globetrotter
Moline , Illinois
Replacement for Bowen water heater?
Is Atwood the best replacement for Bowen water heater and can I keep my original door?
The gas valve on my 63 Globetrotter's Bowen heater is bad and the dealer tells me replacements are not available. So... I will be replacing the water heater. Is an Atwood 6 gal the optimum choice. I really want keep my original outer door so I realize some fabrication might be needed on the venting. Is this possible to do. Also any tips/ tricks for removing the old heater. I've done a lot in houses but the trailer is a new experience. Along with the heater the old copper water lines are going and I am debating PEX vs CPVC is one better than the other or is it just a matter of preference?
63air is offline   Reply With Quote
Old 07-18-2005, 06:35 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
A picture of your existing door would help
I prefer copper plumbing, but PEX would be my next choice.
Tom
Old 07-18-2005, 06:48 PM   #3
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet Cpvc
TOM,
What don't you like about CPVC?
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 07-18-2005, 06:57 PM   #4
TomW's Avatar
1967 26' Overlander
Norm,
I do not have a dislike for CPVC, but for a vibration-prone, somewhat cramped environment, I feel PEX is a better plumbing alternative in a travel trailer. Especially for folks that do not run plumbing for a living.
CPVC is great in that no special tools are required, but its rigidity requires more care being taken to support its runs than PEX does.
Tom
Old 07-19-2005, 07:40 AM   #5
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
Over at Vintageairstream.com they have a great article on how to put the old Bowen door back on the new Atwood(which is your only choice for a replacement):
http://www.vintageairstream.com/rr_topics_hwheater.html
John
AYRSTRM2 is offline   Reply With Quote
Old 07-19-2005, 10:17 AM   #6
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
Nice link, I sure hope to use that in the future! I could help if you had questions on a 70's, but those pics look like the information you need.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 10:13 AM
Water Heater Replacement rpwx Water Heaters, Filters & Pumps 2 04-23-2014 02:43 PM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 06:03 AM
Water Heater Replacement, Others roessler Water Heaters, Filters & Pumps 9 06-18-2002 04:53 PM
