Old 06-25-2012, 08:39 PM   #1
cygria's Avatar
1976 29' Ambassador
peru , Indiana
Replace G10B water heater
i hope i am posting this correctly. I have a bowen water heater, model G10B 9.9 gal for a 1976 airstream that needs to be replaced. Does anyone know what model number i should buy?
Bob and Shawna Indiana
cygria is offline   Reply With Quote
Old 06-26-2012, 03:54 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Any 10 gallon Atwood should be a direct replacement for your Bowen:
Atwood RV Water Heaters
Old 11-08-2017, 07:34 AM   #3
1976 31' Excella 500
Chappell Hill , Texas
I need one too so I'm bringing this post back to life. I have the original Bowen/Atwood Model G10B water heater. The new ones I'm seeing on line don't appear to have the exact dimensions of my old W/H. My question is where do you measure, from outside to outside of the flange or ID of the hole cut out? What do those dimensions the manufacturers are listing actually go to? Also, unbelievably the bottom of flange of the old W/H is behind the factory decorative lower trim piece so that will have to come off to get it out.
tbashin is offline   Reply With Quote
