Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 09-19-2009, 01:06 PM   #1
Profile:  2008 20' Safari SE
Kelowna , British Columbia
Unhappy Rattling pipes
I replaced a defective water pump with an Extreme series 4900. Pump has long slow cycle,and won't run my sink spray nozzle for more than a few seconds.Also on first usage, I have to run the shower to stop the rattling pipes from behind the shower when using the kitchen sink. Instructions say to make sure all the air is out of the system. How do I do this,and is this the problem?
GEOTRAC is offline   Reply With Quote
Old 09-19-2009, 01:48 PM   #2
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Welcome to the forums!
Air in the pipes is normal and it will happen when you pressure to the system. You remove the air by opening the valves one at a time starting with the furthest away from the pump and working your way to the pump. You run each valve until the water comes out in an even flow.
In my trailer the order is:
Toilet
Bathroom sink (hot then cold)
Shower (hot then cold)
Kitchen sink (hot then cold)
As long as you keep pressure on the system, you should not have to do this again. It takes only a few minutes and very little water.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 09-19-2009, 10:37 PM   #3
azflycasters reply got me checking again, and I realized I had forgotten the two drains which I normally use to winterize. i opened them,and heard the air leaving. System is much better now. I should have asked a year ago,instead of asking Airstream. Thanks.
Ventilation pipes Lothlorian General Repair Forum 8 09-25-2008 04:21 AM
what pipes to use? kamo Fresh Water Systems 3 10-23-2006 03:58 PM
busted pipes sfixx Fresh Water Systems 36 04-07-2005 09:51 PM
