Old 05-02-2013, 05:59 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
Quieter water pump - recommendations 23fb
We have the factory Shurflo water pump on ou '08 23FB. It is pretty loud and we are early risers so I hate waking every other site for miles when we use it.
Do you have some recommendations for a quality quiet replacement pump that can run and operate if it goes dry?
Looking for real use recommendations if possible...
Thanks!
bonginator is offline   Reply With Quote
Old 05-02-2013, 06:20 PM   #2
The pump is mounted to bare flooring which acts as a sounding board when the pump goes on.
Try quieting it down by mounting it on rubber grommets.
There are other pumps but all operate using the same basic diaphram design. Using another pump would likely require plumbing modification.
handn is offline   Reply With Quote
Old 05-02-2013, 06:52 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I built a platform using 4 of these...
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-02-2013, 08:43 PM   #4
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
Same pump .... same complaint! I mounted it on rubber which did help, but only a little bit. My next attempt will be a flexible output line which I have read helps by not transmitting the vibrations through the plumbing. I look forward to other suggestions.
field & stream is offline   Reply With Quote
Old 05-02-2013, 08:45 PM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Where can you get the these rubber stand offs? How do they attach to the the floor? Do you need to build a platform and then drill holes and use blind nuts for the rubber standoffs? Then screw the platform down and install the pump on the standoffs with nuts?
Does the existing plumbing line up with the pump when it's raised from the original position?
Kelvin
Old 05-02-2013, 08:53 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Thanks Bob, I like the idea of the rubber mounts and may use it as well. I put in a small water pressure accumulator from camping world which absorbs some of the pressure variations as the pump turns, and gives a little bit of reserve pressure so it doesn't run with every movement of a faucet.
doug k
Old 05-02-2013, 09:00 PM   #7
Boulder , Colorado
doug k
Do you have a link to the product? Sounds interesting...
Old 05-02-2013, 09:04 PM   #8
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I'm considering a variable flow pump.
Sensor VSD Pump - 4.5 gpm - Xylem R4525-743A - Fresh Water Pumps - Camping World
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 05-02-2013, 09:13 PM   #9
dkottum's Avatar
Here's a thread on the accumulator
http://www.airforums.com/forums/f163...or-100341.html
doug k
Old 05-02-2013, 09:27 PM   #10
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Originally Posted by bonginator View Post
...<snip>...
Do you have some recommendations for a quality quiet replacement pump that can run and operate if it goes dry?...<snip>...
Thanks!
The rubber stand-offs should help... You can also wrap pipes in foam rubber if they are knocking against surrounding materials (which can happen at other points than at the pump)...anything to reduce vibration will help make the pump run quieter...
Also, you should avoid running the pump dry. That will allow air to enter the line which will create other problems ...
TB & Greg and Abbey Schnauzer
#3954
Old 05-03-2013, 04:42 AM   #11
Kelvin
doug k
Actually they came from the "junk" drawer of my tool box.
Bosch electric fuel pump mounts.
They looked exactly like these....
If I had it to do over I would use these....no platform needed.
Helpful?
PFC
"Tahawus"
RLC
Old 05-03-2013, 09:22 AM   #12
Boulder , Colorado
Originally Posted by daveswenson View Post
Anyone actually install this? Seems like it would address the noise issue...
I guess I am not the only person who is bugged by the noise!
Old 05-03-2013, 10:01 AM   #13
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Just ordered three as recommended by Bob above, about $9 ea. and small shipping charge, easy to use website order system. We'll see how they work.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 05-03-2013, 10:09 AM   #14
dsrtgrls's Avatar
2010 19' Flying Cloud
Clarkdale , Arizona
Helpful?
does the pump line up ok using them? or are there other adjustments to be made?
"Open paddock 9!"
dsrtgrls is offline   Reply With Quote
