Old 05-09-2014, 09:37 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
Quiet water Pump
Need to find a quiet water pump for a 2003 34ft . Any ideas? Mine sounds like a jet engine. DH
Emh142 is offline   Reply With Quote
Old 05-10-2014, 06:41 AM   #2
1981 31' Excella II
New Market , Alabama
They can be pretty noisy. An accumulator might help. The problem is with the impulse pumps is the pressure pulses radiate through the plumbing amplifying the noise. The accumulator will damp these out. We don't use the pump that much so the noise is not a big issue.
Perry
Old 05-10-2014, 06:51 AM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
The water pump that came with our 2005 Classic (bought used) was alway extremely noisy. If memory serves I believe is was made by "Aquatec."
After a couple of years use it failed and I bought a replacement from a local RV dealer - the make was "Shurflo.
The difference in noise level ... and water volume ..... was like night and day. We can barely hear it operate now.
I suppose it could have been that the "Aquatec" was in problems of some sort since we first got the trailer and just took a couple of seasons to fail completely.
Also, I recall that on one side (intake? delivery?) the "Aquatec" was hard-piped, whereas when I installed the Shurflo I made sure it had a foot of so of flex hose on each side and no doubt that helped a lot.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-12-2014, 04:28 PM   #4
PopHetzler
Emh142's Avatar
Troy , Ohio
Thanks for the info. I checked and have an Aquatec. Spoke with another Airstreamer this weekend and he suggested a Surflo too. I think a new pump is in my future. Was afraid I would wake up the whole camp with an early morning flush so had to walk to the park latrine. What a mess. thanks again. D. Hetzler.
Old 05-12-2014, 04:42 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
The good news, from my experience, is that the noise is all inside the trailer- it's not really noticeable outside.
2012 Dodge Durango Hemi/AWD
Old 05-12-2014, 11:16 PM   #6
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
We put a Flojet Variable Speed R4515-743 into our 2013 FC 30
We replace the water pump when the AS was 3 months old. The old pump was noisy, and had an internal leak (pump cycling on every 30 seconds, and when connected to fresh water had a leak out of the FW tank overflow screen).
The more we've used the Flojet VSD pump, the more we like it. Pretty quiet.
RAH is offline   Reply With Quote
Old 05-13-2014, 04:26 AM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Mounting the pump with some sound insulation under it might help reduce the "drum effect" noise from being screwed to the wood floor in the trailer. Flex hose either side will help reduce noise. We also installed a ShureFlo air expansion tank so there is no water hammer effect when shutting off a faucet that can cause plastic or even PEX fittings to eventually leak.
Old 05-13-2014, 08:13 AM   #8
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
ShurFlo, or FloJet, in conjunction with the small accumulator tank will probably take care of the problem. In addition to that, I put a piece of one inch thick heavy rubber foam under the pump.
For whatever it's worth.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 05-15-2014, 06:54 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Loose (unsecured) pipes will add to the noise also,
Old 05-16-2014, 01:23 PM   #10
2004 16' International CCD
Chicagoland , Illinois
What do you make of this silencing kit from SHURFlo? It looks like the hoses are looped during installation to absorb vibration?
Amazon.com: SHURflo 94-591-01 Pump Silencing Kit: Automotive
Might this help to reduce the pump's noise or is it just a gimmick? Would there be any issues with installing this in conjunction with an accumulator?
Airrogant is offline   Reply With Quote
Old 05-16-2014, 01:39 PM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I made my own flexible hoses because I wanted them longer for looping and needed angled ends to fit my water pump. I added an accumulator later. All is good now.
ID:	212044   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-16-2014, 01:43 PM   #12
Salem , Oregon
Images: 18
Hi,
With accumulator.
ID:	212046   Click image for larger version
2005 Safari 25-B
Old 05-16-2014, 02:07 PM   #13
PopHetzler
Emh142's Avatar
Troy , Ohio
I'm going to try it all. Flojet vs Shurflo? Comments/opinions?
Old 05-16-2014, 04:20 PM   #14
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I did the same as robertsunrus except the use of insulation around visible pipes and under the pump. We use the pump quite a bit this fix works well.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Water pump ??? Noisey or quiet ?? polarlyse Water Heaters, Filters & Pumps 14 08-13-2009 11:35 PM
Want a new water pump, looking for quiet ronstory Water Heaters, Filters & Pumps 2 08-04-2008 11:22 AM
Flo-Jet quiet pump control?? myoung Water Heaters, Filters & Pumps 10 12-15-2006 06:40 PM
Ebay quiet Happycampers Off Topic Forum 3 06-27-2004 10:23 AM
Quiet part of the Community??? GT1963 The Pet Forum 2 01-28-2004 09:16 AM
