Old 05-16-2014, 11:59 PM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Looking at post #12 installation, does the pump have a built in filter or is there an external filter for the larger stuff in the water?
The "plan ahead for service" factory location for our water pump with built in filter that covers the area with water when opened is under two runs of duct work and wires at the bottom of the closet. We managed to get the air expansion tank in, but will contemplate the 1" rubber pad mentioned elsewhere to help with noise abatement.
There are always such great ideas to solve problems in this forum!
Old 05-17-2014, 12:11 AM   #16
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, if you look at post number 11 you will see my external filter which connects to my fresh water PEX line from the tank.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-17-2014, 12:45 AM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
How much noise do some of these pumps make?
Maybe I got lucky by accidentally getting one that won't wake the dead?
Old 05-17-2014, 01:42 AM   #18
switz's Avatar
2014 31' Classic
Images: 8
In our 2013 25FB International, the pump was just below the pillows on the bed, so if one or the other used the bathroom at night and flushed, the other was awakened by the growl noise only inches away from their ears. :roll eyes:
In our Classic, the water pump is down the hall beyond the shower under the closet floor, which resonates like a drum. I am hopeful a rubber pad will help reduce the din to a bearable non-awakening level.
Old 05-17-2014, 06:53 AM   #19
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Yea I could see how right under the bed could be an issue no doubt.
Water pump ??? Noisey or quiet ?? polarlyse Water Heaters, Filters & Pumps 14 08-13-2009 10:35 PM
Want a new water pump, looking for quiet ronstory Water Heaters, Filters & Pumps 2 08-04-2008 10:22 AM
Flo-Jet quiet pump control?? myoung Water Heaters, Filters & Pumps 10 12-15-2006 05:40 PM
Ebay quiet Happycampers Off Topic Forum 3 06-27-2004 09:23 AM
Quiet part of the Community??? GT1963 The Pet Forum 2 01-28-2004 08:16 AM
