Old 07-29-2005, 06:03 PM   #1
Kestrell's Avatar
2005 28' International CCD
Upland , California
Quick boondocking question....
When parked and set do you leave the water pump and water heater on all the time or just prior to use???
Kestrell is offline   Reply With Quote
Old 07-29-2005, 06:23 PM   #2
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
We leave our water heater on, but it probably would save propane if we turned it off while away from the trailer. Your call.
We usually turn the pump switch off when not in use. The pump cuts off once the line is pressurized so leaving the pump switch on probably would be OK.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 07-29-2005, 06:31 PM   #3
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
"Just in time" are the rules we follow
When we do not have hookups we turn the water pump on only we when need it and we turn the water heater on about 20 minutes before we want hot water.
I don't know if any of these two things draw power much from our batteries. But, if they do then we have saved enough to power our LCD TV for the evening.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 07-29-2005, 06:38 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i leave my pump off when away from the trailer. the heater only cycles about every 3 hours or so, i leave it on.
john
you call them ferrets, i call them weasels.
Old 07-29-2005, 07:37 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Pump off when not in use, water heater too.
Old 07-29-2005, 07:42 PM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Pump off, since I am afraid of flooding my unattended trailer by accident.
Water heater stays on, too much work to light a manual pilot several times a day. If I had electronic ignition on it, then I'd probably turn it off when leaving the trailer.
Uwe
www.area63productions.com
Old 07-29-2005, 07:48 PM   #7
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Pump off and water heater off. With my '77 I have to go outside and light the water heater but on the '86 I can get up in the morning, hit the auto light and go back to bed for another 30 minutes while it warms up.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-29-2005, 10:09 PM   #8
Kestrell's Avatar
Upland , California
Thanks, sounds like either way works out okay. I started to worry myself that I was unkowingly messing my systems up.
Old 07-30-2005, 08:20 PM   #9
davidz71's Avatar
1986 25' Sovereign
There have been some horror stories where someone left their trailer in a campground and a hose fitting slipped thereby flooding the trailer floor/rug. I always turn the water off at the faucet when leaving for a few hours so leaving the pump off when boondocking serves the same purpose.
There have been several posts on the forum showing burned up trailers, both fires starting from the water heater area. That is why I rarely leave mine burning while sleeping at night.
Craig
AIR #0078
3.73 rear end
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
quick question is it a 77 or a 76 overlander Our Community 23 10-03-2002 07:21 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
waterhose quick disconnects John Fresh Water Systems 3 04-19-2002 06:58 PM
