Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-21-2004, 03:41 PM   #1
surf'n safari
Profile:
Question with Pressure Pump
I have what appears to be the orginal pressure pump in my 62 Safari. I can't get water out the sinks or toilet via pump. I can get water through hose connect when hooked up. And I was able to "back flush" from that outside connection through the water tank and out its filling tube.
I did find a water shut-off valve from the tank to the kitchen sink-its open. The pump builds pressure, then stops. No air leaks. Is there something I'm missing? Maybe the is not building enough pressure? Please help!
surf'n safari is offline   Reply With Quote
Old 06-21-2004, 09:19 PM   #2
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Sounds like your pump is bad. You filled the water tank using the outside water supply through the system. Try this test. Make sure you have lots of water in your tank. If it is still full from your fill up, leave it like that. Disconnect the water hose running from the pump that is connected to the copper pipe that runs to the kitchen sink. NOT the one connected to the tank. This may be a short hose, but put it in a bucket and turn on the pump. If the pump works water will come out of the hose.
Actually you may have some blockage between the water pump and the pipe to the trailer. Try the test I described above first.
John
AYRSTRM2 is offline   Reply With Quote
Old 06-21-2004, 09:47 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
S'nS
Did you try pressurizing the tank from a different source? There may be a Schraeder valve (like a tire stem) on the filler neck. Try pumping it up with an air hose at the gas station. If that works, then your pressure pump is bad. I have a diagram of the pressure pump, but I don't know if parts are still available.
If pressurizing with a different source doesn't work, look for a bad gasket in the filler neck cap which might be causing you to lose pressure.
Non-contributing deadbeat.
Old 06-21-2004, 11:54 PM   #4
surf'n safari
Profile:
Thank you for the good advice. I did another test. Filled the tank, turned on the pump and placed my hand over the fill cap the the tank. Wow, lots of pressure! Clogged line? Another valve somewhere? A diverter of some kind?I just can't figure this out.
Water pressure question Chitown AirStreamers 1965 Safari 6 12-28-2007 11:40 AM
Help Needed! Water Pump Pressure Diablo Water Heaters, Filters & Pumps 3 05-19-2004 06:24 PM
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 01:12 PM
water pump pressure AccessMaster Water Heaters, Filters & Pumps 3 08-22-2003 10:38 PM
Tire Problem? Pressure Question montanaandy Tires 1 04-22-2003 09:56 PM
