Old 12-03-2007, 09:12 AM   #1
pump wiring
this may be a dumb question. But here we go. the new pump (Shur Flow) came with a red and black wire. The wiring in the wall is black and white. My question is which goes to which? I Assume Red to black/ Black to White?
nbka1bm is offline   Reply With Quote
Old 12-03-2007, 09:17 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
12VDC "normal" is BLack = ground, red = hot
RV wiring: White = Ground, Black = hot just like a house.
So Red to black and Black to white would make sense.
Michelle TAC MT-0
Sarah, Snowball
Old 12-03-2007, 09:25 AM   #3
thanks
that is what I was thinking. Just wanting to be sure!!!!
Old 12-03-2007, 09:27 AM   #4
Keymar , Maryland
THe worst that could happen is it run run backwards and try to fill the tank.
Just don't let it run too long dry or she will burn out.
Michelle TAC MT-0
Sarah, Snowball
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
Water pump wiring ?? Sneakinup Water Heaters, Filters & Pumps 3 06-03-2004 06:18 PM
