Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Prev Previous Post   Next Post Next
Old 09-24-2009, 09:41 PM   #1
Profile:  1984 31' Excella
Ceres, , California
Pump Switch Wiring
I have a 1984 - 31ft Excella and the light for the water pump that comes on when the pump is turned was out. After removeing the control panel I discovered that the black wire that is connected to the light socket came loose from some where. I attached it to one of the orange wiress on the switch that is attached to the control panel it will work ok, but the pump switch in the bath when turn will not turn the light on at the control panel. It work ok for before. Any suggestion where to connect the black wire rather to the hot side of the control panel switch?
lewmad is offline   Reply With Quote
65 caravel galley pump switch cosmos Fresh Water Systems 6 07-22-2009 08:06 AM
wiring light switch LarryO Lights - Interior & Exterior 0 04-30-2009 08:05 PM
Wiring Breakaway Switch The Flintstones Brakes & Brake Controllers 4 03-01-2007 12:15 PM
Pump Switch Chaplain Kent Electrical - Systems, Generators, Batteries & Solar 1 06-28-2004 08:39 AM
water pump switch wheel interested Water Heaters, Filters & Pumps 1 12-11-2003 10:46 PM
