Old 06-04-2014, 12:26 PM   #1
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Pump silencing kit needed?
I just installed a new Shurflo Revolution pump in my 65. I'm still finishing the plumbing, all new PEX... but rather than purchasing the silencing kit, I just bought Home Depot standard sink flexible lines. Has anybody used these for this purpose? I am looking at the inside of the couplings for these lines and they are quite a bit smaller than 1/2" ID. Does anybody that has the silencing kit know if the ID is 1/2"? I don't want to cause any problems with my new pump, but I don't know if there is any real difference with the silencing kit and the HD sink hose. Any thoughts?
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 06-04-2014, 12:30 PM   #2
dznf0g's Avatar
Oswego , Illinois
Pretty sure the silencer kit is 1/2". I think any smaller than that and your pump cannot deliver full flow.
-Rich-
Old 06-04-2014, 02:06 PM   #3
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Yeah, thats what I am worried about. I might need to go to the local RV dealer and see if they have a kit I can look at and buy. I think I'll use the sink connectors on the kitchen sink instead. Thanks for the input!
Old 06-05-2014, 01:07 AM   #4
2004 16' International CCD
Chicagoland , Illinois
I'm not exactly sure if I will answer your question or not. I've got the Shurflo Pump Silencing Kit 94-591-01 here in front of me. It consists of two 36" hoses and two 1/2" NPT-M bushings. The ID of the hoses is significantly restricted at each end by what appears to be rubber washers that I'm guessing help seal the hoses to the bushings.
Airrogant is offline   Reply With Quote
Old 06-05-2014, 01:30 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I can't remember just what pump I bought last year but I do remember I used the same style sink connections as you.
My pump seems to move plenty of water.
The size of the tubing is important , but short lengths of smaller hose matter a lot less than they would if they were long.
Old 06-05-2014, 08:08 AM   #6
1987 25' Sovereign
Oregon , Ohio
This is true, but any restrictions or fittings (90's, 45's, Tees, and couplings) have a smaller inside diameter than the pipe they are being used with, causing a loss of volume and pressure at the outlet end.
msmcv51 is offline   Reply With Quote
Old 06-05-2014, 08:28 AM   #7
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Thanks for the replies. I moved the sink connectors last night to the new kitchen faucet. I am going to get the kit and be done with it. I will look at it when I get it an report back here my findings. The sink connectors were restricted at the bushing, not just the washer.
Old 06-05-2014, 09:48 AM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I guess my point was rooted in practicality. The setup moves plenty enough water to take a nice shower.
Flojet RV Waste Pump Kit Dr. E Waste Systems, Tanks & Totes 12 10-01-2017 05:17 PM
installing pump winterizing kit adonh Fresh Water Systems 2 10-20-2012 10:45 AM
HELP: Onan BF fuel pump - kit / schematics MrJ Mechanics Corner - Engines, Transmission & More... 1 03-03-2012 02:52 PM
AquaJet ES water pump rebuild kit? Wingeezer Water Heaters, Filters & Pumps 3 06-03-2011 02:15 PM
rebuild kit for water pump 76 sovereign chris's 67 Fresh Water Systems 2 03-06-2007 09:18 PM
