Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 01-05-2008, 08:19 PM   #1
cedboone
Profile:  Currently Looking...
Concan , Texas
pump runs, but no pressure?
Just de-winterized our (new to us) 01 Bambi in preparation for our first Airstream camping trip. Filled the freshwater tank, turned on the water pump, and heard the pump humming along. Never generated any pressure though...? Disconnected the intake side from the freshwater tank, turned the pump on. Still humming nicely, but not creating any vacuum.
Do I need to prime this guy or what the heck am I missing here?
Thanks in advance,
cedboone is offline   Reply With Quote
Old 01-05-2008, 08:38 PM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
If you have a valve to winterize with, it may be in the wrong position. It should be located just before the input to the pump. If not that, you could disconnect the input line to the pump and see if you have suction at that point.
Richard
Charter Member Four Corners Unit
Water Pump Pressure PhilMateo Water Heaters, Filters & Pumps 2 12-20-2005 07:16 AM
Water Pump Pressure??? ssolid Water Heaters, Filters & Pumps 3 10-12-2005 11:59 PM
Question with Pressure Pump surf'n safari Water Heaters, Filters & Pumps 3 06-21-2004 10:54 PM
water pump pressure AccessMaster Water Heaters, Filters & Pumps 3 08-22-2003 09:38 PM
Water pump pressure duration? Mr. Bliss Water Heaters, Filters & Pumps 11 04-21-2003 10:31 PM
