Old 12-04-2019, 01:13 PM   #1
2019 28' International
Kennewick , Washington
pump not working
Hi there,
I just purchased a 2019 International, 28' and had it delivered. It was surprising to find that there is water in the fresh water tank. I wanted to empty the fresh water tank but when I push the water pump switch, nothing happens.
On other Airstreams I've had, when you press the button for the pump it makes a chugging sound and will pump any fresh water out of the tank.
What am I doing wrong/overlooking?
Thank you.
Amy
Aimer553 is offline   Reply With Quote
Old 12-04-2019, 01:36 PM   #2
2007 22' International CCD
Need to have use/store switch in ‘use’ position, and open a faucet for starters.
rmkrum is online now   Reply With Quote
Old 12-04-2019, 01:41 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Adding to the above:
There also is a fuse / breaker on the pump. It may be tripped / blown. If the trailer was just winterized, somebody may have bumped the wiring harness / hookup to the pump. Also on the "winterize" side of things, the battery may be disconnected ....
uncle_bob is online now   Reply With Quote
Old 12-04-2019, 02:34 PM   #4
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
You may want to check the electrical connections to the pump. My pump would not run when we were camping at the North Rim of the Grand Canyon. When I inspected the pump, the two wires going to the pump and connecting to the wires from the pump were very poor and sloppy spliced together and wrapped by electrical tape.
I had to disconnect the wires, strip the insulation and re-connect using proper connectors. Obviously a very careless and lazy effort by someone at the factory. this was on a 2015 23FB.
it now works as it should.
Steamy1 is offline   Reply With Quote
Old 12-04-2019, 04:03 PM   #5
2019 30' International
Pennsylvania , Pennsylvania
Not to beat a dead horse, but I had a pump that worked one morning, and after a day of driving failed to work at all.
Upon inspection of the area where the pump was, I found the wire connection that had jostled loose. Plugged it back together and BINGO.
Hope your fix is as easy as that.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 4 04-03-2016 10:16 PM
water pump not working rusty47 Water Heaters, Filters & Pumps 3 09-21-2008 03:35 PM
pump not working... Chuck Water Heaters, Filters & Pumps 23 05-16-2007 10:44 AM
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 01:44 PM
